SOURCE: oil change on my 1990 fzr yamaha 1000
20/50 shouold be fine oil drain plug is under the belly pan
SOURCE: will a gas tank fit from a 1995 yamaha to my 1990 yamaha
no unless you want to modify it to fit which will require a lot of work
SOURCE: spark plug number
The stock plug for your bike is NGK- DP8EA-9
A “very helpful” rating on this answer? Thanks! < And it doesn’t cost anything extra!
SOURCE: yamaha fzr 1000 exup 1990, bike's been standing
this happens after they sit a while, get her started, get her rolling, put her in second gear, hold the clutch in, get her up to 20 miles an hour, hold a little throttle on and slam on the rear brake, this usually will free up the stuck friction plates. If not try it a couple of times, it has always worked for me, also if that does not work for you you have to take the side cover off of the engine (clutch side) and using a flat headed screwdriver, and a zip tie to hold the clutch lever back to the handle bar, place the screwdriver in between the clutch plates and gently pry them apart from each other, on your bike I believe you have 7 friction plates and 6 steel plates. ( if you have to remove the cover go get a gasket first).
