Teh tv turns itself off and can be turned right back on. Recently it went off and when the main power is turned back on it goes into standby immediately. I opened it up and found a blown fuse. Not sur of the position but two are right next to each other, this was the right one. Replaced it 125v 4 amp and it worked for 2 days and now does the same thing? Any Ideas on what is going on? Was manufactured in 1999 so i don't know if it is worth calling for repair or if I could do myself would like to.
Remove original solder from regulator pins, (all four of them)on large heat sink that convergence Ic's are mounted on.Clean contacts with de-natured alcohol and re-solder.By the way,use OEM or better conv. Ic's or you risk re-failure of Ic's.
90% it is convergence board problem. Need to replace STK392-110 IC.
I also found it lights up a red led light on the circuit board when this happens about 4 inches towards the front of the TV in front of where the main power cord plugs into the board. The fuse position is FU106
