SOURCE: ac problems
Sounds like the switches are in the wrong locations , rotate! Thank- you- very-much!
SOURCE: ac not blowing cold after outside temp reaches 98 degrees
Sounds like you have dirty condenser coils. Remove the upper shroud and check the condenser for clean. Take a water hose and gently spray out the coils paying special attention not to bend the coils over with too much pressure. This will allow more air movement through the coils and give you better cooling efficiency.
Hope this helps,
Jeff
SOURCE: Dometic AC fan mode or cool mode wont start. Has a
Some manufacturers use phone line to use as communication between control box on AC unit & thermostat. (very common.) Make sure 120VAC is on, and pull cover off thermostat & look for a glass type fuse possibly blown.
SOURCE: I am a service tech in this area and am working
Confirmed! Those puppies have a pc board problem, so call the service center for your needs.
SOURCE: I have a Dometic duo
It may be your thermostat is broken, the thermostat controls when to cut in & cut out the compressor. Try to jump compressor wires and test it. Does the fan run ? Also, check the breaker box where the fuses and such are located.
Keep us updated.
