I have a kenmore dryer mod#110.62202100 when turn the timer dail u can hear it sort of hum and when u push the start button nothing happens i'vee replaced the start button but it still don't work
It could be the door switch , ohm it out to check.
it could also be the temp fuse located by the blower on the duct , you can ohm it out as well.
Let me know if you have any other questions.
Phil
the humming is coming from the motor,if you can spin the drum by hand and it moves freely you need to replace the motor,if it's hard to move you need to take the dryer apart to see why it's hanging up,the overload resets on the motor that's why after a while you'll hear the hum again,if you hold the button to long you'll pop the overload
It is very possible the humming is not comming from the timer, but the motor. check the capacitor on the motor. it should be a 5 or 8 microfarad cap .replace it. Dont try and run motor like that anymore untill it is checked.
its sounds like you have a broken belt or a bad door swith open the door rotate the drum manually if it feels verry easy to turn that means your belt is broken if not you can check the wires then replace the door switck thanks from gilles
Thanks for the question When you push the start button was thera hum if there is a hum when you push start you need a new motor THanks for the question The appliance doc
