I cn't find where the answering machine is or how to leave a recording for incomng calls
SOURCE: Panasonic KX-T7730 does this phone have answer machine?
try using the call forwarding feature, you can forward it to your cellphone.
SOURCE: How to record miscall on Panasonic kx-t7730
It depends on your phone system.
If you have a TA system it requires 2 or 4 CO (buttons with lights) buttons. Personal CID Log is
6 for indications and 7 for selection. Group is 96 and 97. You don't have to have a SELECT button but it helps.
If you have a TAW or TDA system you only need one button per feature because the navigator key works as a selector button. The code is 54 for personal and 54 plus the ICD group for system.
The sequence to program these buttons is PROG button CODE store
Carl
SOURCE: Panasonic 6.0 dect phone model # KX-TGA641 says
Remove the batteries from all of the phones, put them back in one phone at a time. If this doesn't work, try the phones somewhere else, aka a friend/employer. If they work somewhere else, the issue is with your household phone lines. If not, you should have the phone set repaired.
SOURCE: I am having trouble setting
What's the statlus of your FWD key? Try dialing on the intercom *7105 xxx Where xxx is the number you use to call voice mail (either 500 or 165 normally).
Carl
