Dispenser drawer leaked but solved by gluing the plastic guard back in place underneath front of drawer. Program takes washing powder ok but does not take softner through syphon. Engineer replaced drawer unit, housing and water inlet valve. Don't think he new how to resolve the problem! Became too expensive at that point. Have tried leveling machine - rodding the outlet nozzles. No good.
The detergent/softner dispenser is located above the detergent drawer. A water pipe is connected to it and water entrance and distributed to drawer's cells (following the programmed cycle) by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer. By opening upper machine's cover you will have an access to the dispenser. Disconnect the power cable from the machine before moving to next test !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test by a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
fabric conditioner does not syphon off and drawer leaks ..help
