Motorola Mobility RAZR V3 Logo
Posted on Sep 10, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bluetooth motorola v3 razr
I have no problem using the bluetooth to connect to hands free or when connecting to other peoples phones to receive bluetoothed items. However when i bond with another's phone, which works fine, i then try to transfer a file via bluetooth and get a message saying connection failed. I've never yet managed to send anything, i can receive no problem,what am i doing wrong?
wwlvictoria
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Motorola Mob... Master 1,001 Answers
  • Posted on Jan 07, 2017
wwlvictoria
Level 3:
Renaissance:
Answers
1001
Questions
0
Helped
603942
Points
6027
  • Excellent Bluetooth Receiver,stable connectivity and remarkable signal stability.
  • Smooth call conversation and non-stop and clear music streaming creates enjoyable listening experience.
  • Two-link: Enhanced Bluetooth signal can reach up to 10 meters in open space without obstacles and can be connected with two Bluetooth devices simultaneously.
Amazon com Charm sonic Wireless Portable Bluetooth 4 1 Receiver Wireless...
Anonymous
Level 1:
Problem Solver:
  • Contributor 30 Answers
  • Posted on Sep 11, 2007
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
30
Questions
0
Helped
7228
Points
27
Oh yes, I've had this problem before too. It's a service provider block. They make it so that you cannot send files to other phones so that they can make more money. Some service providers do it, some don't.
Transfer pics frm moto razr v3 to laptop using bluetooth
Check your bluetooth connection with the PC and use Moto Tools suite to transfer photos . Other option is to simply make a connection with your PC and send photos one by one or mark all , send all to PC via bluetooth connection
Brand new phone but cant use bluetooth feature for some reason
Do u power on the Bluetooth... if not then u can't connect any device via bluetooth...
Turn on the Bluetooth by Selecting
Menu > Settings > Connectivity > Bluetooth link
now, select
Set up >Power
Click on Change Button and select On
go back
and select hands free then click [look for devices]
it will search for the device...
From another mobile send a file via bluetooth by powering on the bluetooth.
in Motorola copy or move will send the file via bluetooth.
Contact me if any problem persist at [email protected] ...
Thank you!
2helpful
2answers
Bluetooth pairing on Motorola Razr V3
try to check the setting of your blutoot, check te find me option.
Bluetooth
both bluetooth and the function of phone to setup bluetooth have to be compatible with each other and the phone has to search data base for setup bluetooth if not in there data base then quite possible you have to take too mobile dealer and have software upgrade to your bluetooth
Motorola V3 Bluetooth Problem
I am unable to send music or pictures via bluetooth. I can receive when other people send me transfer through my bluetooth. What must I do.
I can't get my phone to connect with other peoples
I assume you are trying to connect to another phone via Bluetooth. It would help quite a bit to know what kind of phone you are trying to connect to, but here is what you need to have configured on your phone for Bluetooth file transfers:
1. Create a link between your Motorola RAZR Phone and any Bluetooth Accessory 1.0 and up, you need to turn the Bluetooth connection "on". This is how: Go into your phone "settings". > Then select "Connection" > "Bluetooth Link" > "Set Up" > "Power" > "On". The connection will stay on until you turn it off. We recommend to turn it off when not in use to preserve battery life.
2. To connect your RAZR to another Bluetooth hands free kit or headset, go into "Settings" > "Connection" > "Bluetooth Link" > "Handsfree" > (Look for Device). You phone will scan for available devices located within the range of the RAZR, approx 30 feet away. If your cell phone is already connected to a Blue Tooth headset, you must disconnect from it to find other devices. Once you have identified your bluetooth device, highlight its name and click on the "select" button.
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is usually provided by the Bluetooth device manufacturer, not the RAZR (unless you are connecting to another phone). Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
4. You can now "Copy" media files to the phones nearby that you have connected to. Copy is an option while browsing through the files.
Can't connect with other peoples phone
Pairing a Jabra 250 headset with my new motorazr2
Here is what you need to have configured on your phone for Bluetooth connections:
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is usually provided by the Bluetooth device manufacturer (in the manual), not the RAZR (unless you are connecting to another phone). Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
Motorola v3 bluetooth
hi,
Just switch on the bluetooth of ur hndset 7 tell othr people around u to do the same.After then click on the search devices option in ur mobile , it will detect the mobiles of othr people around u after that select the persons with whom u want to connect and share the data .
Gizmo 1
8answers
Problem with the bluetooth on my motorola v3
HOPE THIS HELPS: http://www.motorola.com/mdirect/manuals/V3_9501A42A.pdf
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
