SOURCE: Takes dishwasher hours to complete cycle
this sounds like the electronic timer in the circutry control board , if you still have the warranty you should use that , otherwise you will need an electronic tech, that works on these new electronic controlled appliances
SOURCE: Hi! My Bosch began by tripping the breaker during
Hello
Welcome to Fixya.
Based on your post,"...Even when the dishwasher is off I cannot reset the breaker unless I kind of move the machine around a bit. Sometimes it pops the breaker just closing the door..."
These are the most common reason for these Bosch dishwashers not having power.
#1
I would start by first shutting off the breaker. Then removing the kick plate ( access panel at the bottom ) and checking the wiring at the junction box for the dishwasher 120vac supply line.
Remove the murret's and visually inspect the wire for "resistance burn" and strip the wires back and install new fastener's if necessary to repair.
i.e.
This is actually quite common to find a wire connector come loose due to improper fastening and once the unit is in use for a while the connections heat & cool, become loose from normal operating vibrations and burn up from all the added heat caused by "resistance".
#2
A wire severed inside the door panel, hence the breaker trips by just moving the door in an open/close motion.
Check thoroughly in this location...
The end result is tripping the breaker and no power to the controls.
Check it out and post back what you find. Thanks for visiting "fixya" and please take a moment to rate the solution/suggestion provided here for you.
Good luck.
Regards,
Macmarkus :)
SOURCE: GE dishwasher GSD2230 won't drain
Hi Dishwasher not
draining issue usually occurs due to kinked drain pipe, clogged drain filter or
drain pump. Check the drain hose for any visible clogging, remove if present.
If no visible lint is present then remove then turn off the dishwasher and remove
the drain hose and check for any visible clogging. If still not visible then
the drain filter or drain pump is clogged and you'll need to clean the drain
filter and drain pump. Also, check for any food pieces stuck near the pump
impeller. Please note that
dishwashers don't drain out the complete water such that heating element
doesn't overheat. Hope this helps...
Please post back for any further assistance. Daniel
SOURCE: Dishwasher won't drain.Leaves several inches
Check for blockages in the base of the dishwasher under filter etc.
Also make sure the kitchen drain is clear and if you have garbage disposer run it prior to running the dishwasher.
Also need to confirm if the dishwasher pump is actually operating during the drain cycle. If the pump is faulty then it will not drain. Provide full model number of dishwasher if you need further assessment of the problem. Good luck.
SOURCE: whirlpool built in dishwasher DU840SWKQO
Hi Thanks for using FixYa. If the cycle doesn't
complete, then the first thing that should be checked is the Timer and then the
heating element. Timers don't often fail. But if every other part of the
dishwasher seems to be working properly and the timer knob seems to be stuck in
one place--doing one function continuously--the timer may be at fault.
Dishwasher timers can't be repaired. If yours is defective, replace it. Many
dishwashers heat the wash and/or rinse water to a higher temperature, as the
cycle calls for it. In these cycles, the dishwasher pauses after it has filled
with water, waiting for the water to reach the pre-set temperature. What
happens next depends, as follows: On some units, the pause is timed and the
unit continues after the allotted time. On others, the cycle can't continue
until the water reaches the higher temperature. If you have this type of
dishwasher and the water isn't being heated (say, because of a problem with the
heating element or thermostat), after the unit stops at the heating cycle, it
never continues. When you repair the heating-system problem, the "cycle
problem" is fixed too. Please accept the solution if the
issue is resolved or post a comment for further assistance. Thanks Rylee
Hi - The issue may lie with the door latch; a door switch is used to start and stop your dishwasher. It's a safety feature that won't allow water to flow with the door open. With a faulty door switch, there is a chance your dishwasher won't start at all. Dishwasher door switches are about an inch long. They are usually black but can be red. There are metal prongs on the body of the switch called terminals. Some door switches have two terminals and some have three. If your door switch is OK, check the timer assembly. This controls when and how long power is sent to other controls on your dishwasher. If these controls don't receive power, they won't work. The timer assembly contains a motor. Check this motor as well. It is often cheaper just to replace the timer motor rather than the complete assembly. My last suggestion is to check the cycle selector switches. These switches indicate cycles for washing, drying, and setting the temperature of the water. If one of your switches is the problem your dishwasher may not start. Dishwasher cycle selector switches tell the timer which cycle to run by opening and closing electrical circuits. Most selector switches are six to eight inches long. They are usually black and have terminals. By testing each one of these parts with an ohmmeter you should be able to determine why your dishwasher is not working. It is possible for other parts to fail but these are the most common parts to check. If any proves to be ineffective, I strongly suggest contacting a professional to move forward accurately.
