Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
Check for blockages in the base of the dishwasher under filter etc.
Also make sure the kitchen drain is clear and if you have garbage disposer run it prior to running the dishwasher.
Also need to confirm if the dishwasher pump is actually operating during the drain cycle. If the pump is faulty then it will not drain. Provide full model number of dishwasher if you need further assessment of the problem. Good luck.
Posted on Aug 30, 2011
I Have a Tappan Frigidaire Dishwasher Model #61-1072-10 I have checked for blockage and it is free, but it will not drain. If it is the pump, do you have parts?
Most likely you need to get inside and check the impeller assembly (item 3 in diagram).
The unit works from a single motor which changes direction to allow for wash cycle or drain cycle.
http://www.searspartsdirect.com/partsdir...
Have you tried canceling the cycle? To cancel, turn the on/off switch to on, then press and hold for three seconds the two buttons labeled "Cancel Drain". Keep the door closed for the next minute so that the dishwasher can complete the cycle. During this time the pump will remove any water from the washer. Also you will notice that Bosch dishwashers always leave a little water in the system to keep the seals from drying out and going bad.
Hope this helps
Jan 20, 2013 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Sep 28, 2012 | Dishwashers
Dec 08, 2017 | KitchenAid 24 in. KUDU02FR Built-in...
Jan 25, 2012 | Dishwashers
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Mar 04, 2011 | Kenmore Dishwashers
May 30, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
Aug 12, 2009 | Whirlpool DU850SWPB
Jul 23, 2009 | Whirlpool 24 in. DP840D Free-standing...
Jan 16, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Jan 08, 2009 | GE GLDA690MWW / GLDA690MBB Built-in...
Dec 31, 2015 | Whirlpool Gold 24 in. Built-In Dishwasher...
Sep 17, 2014 | Whirlpool Gold 24 in. Built-In Dishwasher...
1,168 people viewed this question
