I'm getting the high pitched "Overload" whine and red light, when I only have a PDA plugged into the UPS. I've taken it in to Batteries-Plus to check the batteries, and they test out almost as good as new in Voltage and Amperage.
Any ideas?
Replace 24v dc small fan, it does not work!
You can buy a new one here
https://www.alliedelec.com/Search/ProductDetail.aspx?SKU=5920640&MPN=OD4010-24MB&R=5920640&SEARCH=5920640&DESC=OD4010-24MB
Its is the small internal fan and yes any small fan of 18-24 volts will work the fan only reaches 24 volts when the unit is under load during power fail operation,most of the time most of the time however with normal 120 input conditions and under medium load the fan is only supplied with about 15 volts. this is because APC is now a typical amarican company tryin to save money for them selvs while supplying thier custermers with **** just replace the fan with sumthing the same or at least ball bearing should eleveate the issiue
same thing
Turns out "charger" part of UPS had failed.
Had power failure. UPS now has continuous tone. Replaced the battery but the tone is still there. Powerchute software says overload but nothing is plugged into it.
