SOURCE: I have just installed the
YOu need to make sure that the maestro you installed is designed for use with electric motors. CHeck out this page on the lutron site... http://www.lutron.com/CMS400/page.aspx?id=16955&mn=1797. THese are the dimmers you can use with a fan. If it is in the same box the magnetic interference can cause the types of reactions you are mentioning.
If this is not the problem you need more info-- is the light part of the fan, is there a separate wire for fan motor and light? what type of switch is controlling the light (assuming the maestro dimmer is controlling the fan motor etc...
SOURCE: 3 pole dimmer not completely working
there is not way to know how the wires are run by the description.
it is possible to connct true 3-way switch, it will required additonal pair of wires to all 3 switches (meaning 3-14/3 wire).
so call 3-way switches is only two way. I have not seems a real 3-way switches.
go to the following site. they a connection diag. for the switches.
http://www.homeimprovementweb.com/information/how-to/three-way-switch.htm
SOURCE: LUTRON DIMMER
The Lutron Maestro dimmer isn't rated or designed to operate low voltage lighting as it is a 120 V-AC rated electronic dimmer. You should either install a standard low voltage ON/OFF switch on this installation or obtain a dimmer rated for use on low voltage lights.
You need special low voltage dimmer designed for use on the low voltage pucks lights you have installed. Usually the low voltage is either 12, 24, or 36 volts, depending on the manufacturer of your particular light set. Once the correct dimmer is in place, the problem with the flickering and pulsing of the lights, should cease.
If you still are having this problem and you can't find a low voltage dimmer, you can contact the maker of your low voltage light kit and they can provide you with an acceptable dimmer option for your lights.
Most Home Depot and Lowe's carry the low voltage puck light kits, and usually have accessories for these lights, including dimmer switches that will work with them.
Hope you find this Very Helpful and best regards!
PS: I found this old, unanswered question and wanted to provide a solution to close out the problem and clear the question from the site.
SOURCE: Dimmer won't dim or turn off
Hello Justin, The dimmer you are having the problem with is very likely defective and should be replaced. If you still have the receipt and purchased it within the past 30-90 days from either Lowe's or Home Depot, they will allow a return for full credit and you can get a new one.
If you got this from another store, again, the receipt will be key in getting your money refunded and a new replacement.
Since many manufacturers have started to use more offshore facilities for making their products, there has been an increased amount of faulty or defective units, but the good news is that the prices have remained reasonable and the manufacturers are willing to replace defective products since they know of the quality issues.
If you don't have a receipt, hopefully you charged it on a credit card, so the big box stores can find it using your credit card data.
As an electrician, I've experienced more and more defective dimmers in the past several years, so much so that I typically get a couple of extras for each home I'm wiring. Just remember to tell the returns person that the unit didn't work so they can RTV (return to vendor) the dimmer for quality tracking, etc.
I hope you find this Very Helpful and best regards!
Testimonial: "Thanks, I appreciate your help!"
SOURCE: Lustro Maestro MA-LFQHW-WH Fan/Light Dimmer
something is messed up for sure... two solutions.... disconnect outlet and cap wires.. or open up both boxes and see where / how they they wired the outlet into the fan/ light control and disconnect it there and then pick up power for the outlet from the black /white wires BEFORE the dimmer control
