Cars & Trucks Logo
Anonymous Posted on Aug 19, 2013
Ok so when I'm sitting in park and running, If I pushed the peddle slightly to rev up the engine and let off. She will go up fine but when she comes down she will studder and almost die out. If I shif
Greg Bernett
Level 3:
  • Cars & Trucks Master 2,993 Answers
  • Posted on Aug 19, 2013
Greg Bernett
Level 3:
Answers
2993
Questions
Helped
2783196
Points
13428
Couple of things....fuel filter could be pretty clogged....fuel pressure regulator is bad....
To make a better fix for you, can I get the info about your vehicle? Year/model/engine size?
Thank you.
  • Anonymous Aug 19, 2013
    Its a 1990 f150 4.9L straight 6, 98,000 miles, last owner didn't take care and beat it up pretty good. Here's what I've done so far, distributor cap rotor, plugs wires, fuel filter, oil oil filter, throttle position sensor, idle air valve, trans filter, that's it so far I believe.
3 Related Answers
Anonymous
  • 404 Answers
  • Posted on Jan 05, 2009
SOURCE: engine bogs and studders in low rpms usualy when warm
check head gasket look in radiator when cold,see if the water bubbles when cranking.
Anonymous
  • Posted on May 03, 2009
SOURCE: my car seems to be studdering and when it idles to low at a stop it shuts off. then sometimes it cant accell with out studdering so much i have to park it. engine is 13 months old.
I have the same thing right now and went to change spark plugs when you pull the wires out and theres oil down in there you need a valve cover gasket runs 39.99 49.99
Anonymous
  • Posted on Jul 23, 2012
SOURCE: 1996 VW Jetta with 2.0 engine. Dies when slowing from high RPM
I would check the EGR if your car has one it could be sticky, A Renault laguna we had did the same thing, died when letting it down to idle but would
recover, or when it died it would run fine on idle when restarted.
EGR was sticking on it. Vacuum lines could also be an issue.. EGR need vacum to work properly. Trotle body could also be worn, but normally that gives you an uneven idle.
Rpm rev upward when car is idling in park
Auto idle in cold weather most new cars do it to warm up engine faster
When I shift my 1990 f150 4.9l straight 6, into reverse i dies out. Also if it's in park and I rev the engine with a quick push of the peddle it will rev up but when it comes down it goes so low it almost...
Yea , take it to a qualified technician an have diagnostic's run ! Do go by guesses an replace a bunch of parts the vehicle doesn't need . Could be any number of thing's . Diagnosing Intermittent Stall Concerns
Looses power under a load put in neutral give gas runs good
sound like fuel filter stopped up.if you have distributor type engine your idle speed could be too low and ignition timing off a little.
Push gas peddle and once i reach about half throttle the engine bogs down almost as if it is going to stall Its not the fuel pump or the filter when vehicle is in park and i push peddle to the floor the...
check your TPS throtel position sensor. and the vehicle has a rev limiter so it wont over rev n park and nutral. but thats the first thing i would check do to many TPS's wear out and can get dead spots in them.
1helpful
1997 jeep idle problems and tapping from a part under the hood
check with a scan tool for any trouble codes, possibly the o2 sensors are gone, the tapping is a lubrication problem try to clean the mesh on the crankcase or a engine cleaning procedure.
Accelerator
Is automatic or stick? If automatic your trans is burn up if stick your clutch is smoked
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
