The water sprinklers may not be working to spread water to all dishes. If for any reason dishes or something prevents them from turning, water will stay in the bottom and not clean the dishes.
Good Afternoon heartbrea158, I am happy to assist you. If the dishwasher is not cleaning, typically, this is a sign that the water temperature to the unit is not warm enough. The water temperature should be at least 120f and no more than 130f. I advise turning the hot water on at the sink (or faucet closest to the dishwasher); allow the water to get as hot as possible. Are you using rinse aid? Use a rinse agent to increase drying and cleaning performance. When was the last time the filter was cleaned? If the spray arm can manually rotate, then another possibility may be that not enough water is being pumped to the spray arm. If you tap the delivery tube that feeds this nozzle and the water pressure jumps immediately; the problem lies either with the pump or maybe the impeller, for some reason the full flow of water is not making it to the upper spray arm. Should all basic troubleshooting measures fail contact a certified technician to narrow down the precise issue before investing in parts that may or may not be the root cause.
SOURCE: Garbage Disposal backing up in dishwasher
Most dishwasher have a check valve at the pump to prevent water from backing into the dishwasher. If the pump is electric there is a rubber flat that may be gone or not working properly. If that is the case you need to replace the pump. If the pump is part of the motor assembly then the pump and motor will need to be replaced. One other thing to make sure of is that you have the drain hose looped to the top od the dishwasher and then to the disposal conection. Its called a drain loop and all dishwashers should have it. Good Luck
SOURCE: My dishwasher is stuck on clean
It could be stuck on clean because it is waiting for the water to reach temperature before continuing. If the element is faulty then it will sit there forever.
SOURCE: RESIDUE ON DISHES-NOT CLEANING WELL-DETERGENT NOT DISSOLVING-LONG CYCLES
The first thing to check with any of the newer dishwashers is the water temprature coming into the machine and the amount of water coming in. Since you are having trouble with the detergent dissolving, I expect the water is not hot enough. Many of the detergents require 140 degrees f to dissolve properly. The incoming water should be 120 degrees minimum, then the dishwasher will heat it up some more. The cooler the water, the longer the cycle will take. It won't advance to the next step until the water reaches a certain temp, depending on the cycle selected and the model of dishwasher. If the dishwasher has to heat the water too much, it will cause the heat element to fail prematurely. If your water heater is set to the average 130-135 setting, then you may be able to solve your problem by running the hot water at the sink before turning the dishwasher on. This will get the cold water flushed from the pipes so the washer fills with hot water on the first fill. Also. start the washer in a cycle, let it fill and start washing. Open the door and see how much water is in the tub. It should come up to the bottom of the heating element. Post back and let me know what you find out.
SOURCE: Dishwasher keeps running & won't clean dishes
If bottom arms is falling of then the assemly is wrong. Pull eveyrthing out and put the arem in before the other parts. reassemble and twist the horseshoe piece till it locks. that should keep the arm in place
SOURCE: My dishwasher is not washing dishes on the top rack...
HI,
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary . If the motor gear is broken, replace the sump and motor assembly . Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
thanks,
