Hello
There are some things you can try, however, if your Maytag dishwasher is not getting your dishes as clean as you would like. Maytag recommends several processes for fixing this issue with your dishwasher.
Do not run your Maytag dishwasher while hot water is being used in other parts of your home, such as washing clothes or showering. Hot water is needed for your Maytag dishwasher to properly clean dishes.
Run water in the sink in your kitchen until it gets very hot. Then, turn on your Maytag dishwasher. This will ensure that the water cleaning your dishes is the hottest possible temperature.
Clean your Maytag dishwasher to improve the cleaning results for dishes. Run your dishwasher on a short wash cycle and wait for it to fill up with water. Stop the cycle and add about 1/3 of a cup of rust remover to the dishwasher and finish the cycle. Run your Maytag dishwasher through one normal cycle with regular detergent to finish the cleaning process.
Check your detergent. Old detergent or those that have been exposed to moisture can be clumpy. This detergent will not clean your dishes as well when loaded into your Maytag dishwasher. Purchase fresh detergent.
Use extra detergent when washing dishes that have a lot of built-up grease or food particles. The extra amount of detergent is needed to get your dishes clean. Choose a long cleaning cycle to clean these dishes.
Fill your Maytag dishwasher properly. Dishes should not be stacked on top of each other or excessively crammed into your dishwasher. This will keep the dishwasher from adequately cleaning all areas of your dishes and from rinsing them thoroughly.
Posted on Sep 13, 2011
Most likely buildup over the years. I used Dishwasher Magic and it cleaned the buildup. It is a Citric Acid mix. Tang can also help clean the buildup believe it or not.
Posted on Dec 13, 2011
Mar 07, 2015 | Dishwashers
on Dec 10, 2009 | Dishwashers
Jan 13, 2013 | Dishwashers
Aug 04, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Jun 21, 2009 | Indesit 24 in. IDL500 Built-In Dishwasher
Jun 01, 2009 | Frigidaire PLD4375RFC Dishwasher
Jan 11, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Jan 05, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Feb 24, 2008 | Frigidaire 24 in. PLD2850 Built-in...
Aug 26, 2007 | Frigidaire 24 in. FDB126RB Built-in...
2,619 people viewed this question
