Because of lack of information on this radio I will have to say its stamped the same way as the 9001z which is top secret because even midland doesn't have a manual on it . If you look at the board with a magnifying glass you will see the variables are marked with like vr-1 might say mod, if that's the one then turn it all the way to the left for max mod. You have to look at each variable and next to it it will have what function it does .
SOURCE: modulation on 1001Lwx midland cb
hello,
The limiter is what limits the modulation. Often times there is a pot that you can turn to adjust it. To get more power and swing out of your radio do this DM1 is the mod limiter RVM1 is the mod pot. Adjust this for maximum modulation. Spread the coils marked Lt5/LT12 just a little Spread LT7/LT11 a lot.
Regards,
Tony
SOURCE: garbled modulation midland 1001z. I
the ANCE is DM1. you can adjust the.modulation by turning it. you can also just back the Mic gain down until the aaudio is cleaner.
