20 Most Recent Midland 5001 40-Channels Base CB Radio Questions & Answers
3answers
Brand new Midland 5001z blows fuses immediately after its turned on. I tried the power cord on Cobra 25 that has the identical plug configuration and its Ok. I don't have the receipt as I got it a
bad final also check for any burned resistors in the area. If the final caused the resistor to burn the just replacing the resistor it would burn the new one also.
7/10/2016 8:48:10 AM • Midland 5001... • Answered on Jul 10, 2016
Adjust modulation pot midland 5001
because of lack of information on this radio I will have to say its stamped the same way as the 9001z which is top secret because even midland doesn't have a manual on it . If you look at the board with a magnifying glass you will see the variables are marked with like vr-1 might say mod, if that's the one then turn it all the way to the left for max mod. You have to look at each variable and next to it it will have what function it does .
6/22/2015 1:13:19 PM • Midland 5001... • Answered on Jun 22, 2015
I just got my new
check the SWR. the antenna may not be tuned. Also, you may be hearing skip. If so, they are thousands of miles away, and you don't have enough power to talk to them.
Find some one close to test it.
11/25/2010 7:58:51 PM • Midland 5001... • Answered on Nov 25, 2010
Just got my new CB radio and i can hear people
Hi, my name is John. Welcome to FixYa. Turn your MIC GAIN to MAX. Good luck and thanks for choosing FixYa......John
11/6/2010 7:07:28 PM • Midland 5001... • Answered on Nov 06, 2010
Hey my radio wont recieve
Here are some things to check.
  • Try a different mic. With out a properly functioning mic, the radio will not go into receive mode.
  • Make sure the RF gain is up all the way.
  • Make sure the squelch is not too high.
  • Make sure the radio is not in PA mode and is on CB mode.
If none of the listed fixes your issue, there may be a more serious problem with the radio. It will need a tech.
10/8/2010 4:42:06 AM • Midland 5001... • Answered on Oct 08, 2010
Ive been useing my cb
Hi take over
Sounds like you may have a defective radio and may need to send it back. I had the same problem with mine but was out of warranty so i dove in and found mine to be the low voltage transmit circuit.
This sounds like it may be to new to remove the covers off of though so I would allow midland fix it. hope I helped .
Thanks Ray
8/24/2010 4:46:14 PM • Midland 5001... • Answered on Aug 24, 2010
Ive been using my cb and up untill today it has
The microphone isn't working - either because the audio pre-amplifier has failed or, almost surely, the flexible cable that connects it to the base has a break in it.
Just replace the microphone.
8/23/2010 10:59:56 PM • Midland 5001... • Answered on Aug 23, 2010
Midland 5001 40 channel cb radio all is fine with
Hi Tom
Ya know I have that same radio with the same chirp. I have asked many to tell me if they hear the chirp on the air and no one has heard it but me. I know what it is but i wont fix it due to the fact it is the only radio that does that to me and i think its kinda cute for it to do it. Now to let you in on the secret is that for the radio to go from rx to tx is handled by transistors plus the computer has to give final say so to tx. So the chirp is developed by the switching and computer turn around times to allow you to talk. I hope this helps.
Ray
8/23/2010 7:30:41 PM • Midland 5001... • Answered on Aug 23, 2010
0answers
Midland 78-999 40 Channel SSB/AM CB Radio Base Station. I am looking a user manual pdf
Question edited for clarity. https://www.transmission1.net/viewtopic.php?t=58817 Or Paper copies
VHTF MIDLAND 78-999 AM/SSB Transceiver Owners ...
eBay https://www.ebay.com > Manuals & Magazines A great manual for the classic 78-999 AM/SSB CB base station which is a Legend ... VHTF MIDLAND 78-999 AM/SSB Transceiver Owners Manual with 5 Schematics! US$29.95 · ‎In stock
Midland 78-999 AM/SSB CB Radio Owners Manual w ...
eCRATER https://theclassicmint.ecrater.com > midland-78-999-a... Complete OPERATORS manual with schematics. This is not a service manual, this is the owners manual the radio came with. As shown, mint condition as NEW. US$31.95
6/4/2023 4:20:21 PM • Midland Radio... • Answered on Jun 04, 2023
Where can I get a 12volt dc power cord. For a midland hand held 75-779 cb radio
any place that sells electronics
9/20/2021 12:54:31 PM • Midland Radio... • Answered on Sep 20, 2021
Midland cb radio 40 ch transceiver
Here you go
OWNER'S MANUAL midlandusa.com - Midland Radio
https://midlandusa.com > uploads > 2016/12 > 75-...
PDF Midland 75-785. 40 CH AM HANDHELD CB TRANSCEIVER. 78-785 is a 40 channel Citizen Band Mobile operation, that is big on performance. 15 pages
HANDHELD CB RADIO - Midland Radio
https://midlandusa.com > uploads > 2012/06 > 75-...
PDF Sep. 10, 2012 - Midland 75-785. 40 CH AM HANDHELD CB TRANSCEIVER. 78-785 represents state-of-the-art high-tech engineering. Designed for 40 channel Citizen ... 8 pages
Midland 75-785 Owner's Manual - ManualsLib
https://www.manualslib.com > ... > Radio
View and Download Midland 75-785 owner's manual online. ... DC 13.8V CHARGE 40 CHANNEL CB TRANSCEIVER 75-785 SQUELCH VOLUME DC 13.8V CHARGE page 4.
75822 HANDHELD CB TRANSCEIVER User Manual G-300 ...
https://fccid.io > Midland Radio Corporation > 75822
75822 HANDHELD CB TRANSCEIVER User Manual G-300 owners guide Midland Radio ... Owner's Manual Model Number 75-822 Features Include: 40 CB Channels 10 ...
USER MANUAL Midland 75-822 40-Channel 2-in-1 CB Radio
https://www.search-manual.com > midland-75-822-40-...
User manual, Midland 75-822 40-Channel 2-in-1 CB Radio, Midland, 75-822, 40-Channel, 2-in-1, CB, Radio, with, Weather, Alerts.
8/18/2021 11:21:07 PM • Midland Radio... • Answered on Aug 18, 2021
Midland two way radio 7Q-0351C What size fuse is require on the 12 VDC power lead?
I think you meant 70-0351c? I believe this is a 60 watt transceiver. So if you remember ohms law P=IxE or power equals amps times volts so 5 amps times 12 volts equals 60 watts. Use a 5 amp fuse.
8/29/2019 7:24:32 PM • Midland Radio... • Answered on Aug 29, 2019
2answers
Need a manual for midland 79-265
If its a real old radio Midland may not have it---Google that model number with "manual" to see what is available.
5/30/2019 1:05:06 PM • Midland Radio... • Answered on May 30, 2019
Hi . I want to buy midland gxt 1000vp4 two way radio . But the charger of that is US standard 110 /60 . In my country its 220/50 . So is there is an eazy way to make it work ? .. thanks.
go to radio shack or best buy you need a step up transformer .or you can buy a travel kit and you dont need a lot of watts transformer to do this dont let them rip you off on a high watt one.
3/1/2019 5:42:49 PM • Midland Radio... • Answered on Mar 01, 2019
Want to know if I can silence call beeps compleatly on all my radios. Midland X-talker T50 Series...Thank You
Yes. They call it silent operation. To set SILENT OPERATION, press the MENU button until the display shows a "bP" icon. Select "on" or "oF" by pressing the s\t buttons and push the PTT key or MENU button.
11/2/2018 6:42:07 PM • Midland Radio... • Answered on Nov 02, 2018
Midland 5001 40-Channels Base CB Radio Logo
9 questions posted
Top Midland Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Midland Radio Communications
Most Popular Question
ive using cb up untill today
  • Radio Communications
