Hi, here is a practical tutorial about how to transfer files from old iPhone to the new one: https://bit.ly/3cWw8iP
Just check it out if you are still looking for a solution! And hope this helps.
You must back up your iPhone 4 to itunes then connect your iphone 5 to the iTunes then choose restore to back up. Please refer to the video below.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
Back up your iphone 4 to itunes then restore your iphone 5 with your iphone 4 backup from itunes.when itunes asking restore from backup or use as new iphone then select restore from backup and select your backup file of your iphone4.every single thing from your iphone4 will be restore to your iphone 5.contacts,sms,pictures,notes,everthing
Thanks for your reply but, as I said, I don't anything else than my SMS message.
My iTunes backup has been spoiled by a jailbreak and I wish to have a clean iPhone, and restore ONLY my SMS messages, not the rest.
Thanks
Well,i had once try this software called "wondershare dr.fone",it can extract iphone backup from itunes and u can choose what item(s) u like to restore to your iphone 5.but as i remember,i got only the free one so it was limited.have you try this?
SOURCE: I got a new IPhone 3. I downloaded a few apps
That's because you have to shut of the data services when you rely on wifi. all apps are set to use data. However it's going to use the data plan before it even thinks about wifi. So if you shut off the data while at home. You'll force it into wifi mode.
SOURCE: Hi, my name is Daniel Richetti and I write from
I would recommend contacting the publishers of Draw 4 Free, their contact information should be in the app store. If you can not contact them, i'm sure there are many google articles that would help! also if you are new to objective-c i recommend ordering a book on how to program. i started recently and it helped greatly!
SOURCE: Can I retrieve deleted sms
If the deleted text messages were present prior to the last sync of your
iPhone with iTunes, you can retrieve them by restoring your iPhone from
your iTunes backup, which should restore all text messages that were
exchanged prior to the same. To do this, please follow the enlisted
steps:
1) First, go to iTunes > Preferences > Devices, and check the box Disable automatic syncing for iPods and iPhones, then click OK.
2) Now, connect your iPhone to your system.
3) When the iPhone appears in the left menu list under Devices in iTunes, right-click on it and select Restore from Backup on the drop-down menu.
Now,
it should restore your iPhone from the last backup and restart the
same, and hopefully retrieve the text messages exchanged before the
sync.
Otherwise, there is no way to recover them.All the lost data cannot be retrieved.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
