2006 Chrysler PT Cruiser Logo
Posted on Apr 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2005 pt cruiser misfire low rpm
2005 pt cruiser misfires at low rpm
mike loshbough
Level 3:
President:
  • Master 1,011 Answers
  • Posted on Jul 31, 2009
mike loshbough
Master
Level 3:
President:
Answers
1011
Questions
0
Helped
504569
Points
3546
Have your plugs and wires checked for replacement:)
Remontti-J
Level 1:
  • Contributor 32 Answers
  • Posted on May 29, 2009
Remontti-J
Contributor
Level 1:
Answers
32
Questions
Helped
32035
Points
88
Spark blugs or wires are the usually the root cause.
I replaced new spark blugs. After one month I have some misfire, so I install new low cost wires, all ok, but after one month I got same fault again.
So I buy original wires, but same fault again =(
Well, I take a closer look and I found a faulty insulation of spark blug.
Here is a photo of it:
http://www.ptcruiser.fi/ptgalleria/albums/userpics/tulppavika.jpg
and I replace new spark blug, now it is working...
What causes a 300 and 303 and 300 misfire on 2005 pt cruiser
Google all the possibles
TYPE: OBD PO303
Chrysler OBD PO 300
2answers
Rough idle problem
hot or cold. or both
what is RPM at rough idle, too low,, below 800 rpm?
its misfire, do a tune up.
What does obd code p0301 on 2002 pt cruiser mean?
Trouble Code: P0301
Cylinder No. 1, 2, 3 or 4 Misfire Detected
Trouble Code Conditions: Engine is running; atmospheric pressure, fuel level, battery voltage, engine speed, engine load are above minimal predetermined specifications; the engine is not in fuel cutoff and intake air temperature and coolant temperature are within normal operating ranges; there are no DTCs relating to ECT, CMP, CKP, MAP or IAT Sensor, to Crank rationality, to Crank Sensor Learn invalid, or to System Voltage. If total misfires detected are greater than 7% during the first 1000 rpm, or are over 3% after the first 1000 rpm, or are 25% during any 200 rpm with suspect cylinder misfire counter more than 80% and no other cylinder misfire counters above 80%, this DTC will set. The MIL will flash after first trip occurrence and will be steady after second trip.
Possible Causes:
Fuel system problems existErratic CMP or CKP Sensor signalsIgnition system problems existEngine mechanical problems existPCM has failed
2005 PT CRUISER ENGINE LIGHT FLASHING AND CAR WONT ACCELERATE ALSO BUCKING AND JUMPING? PLEASE HELP
the light flashes when damage to the converter is happening,either by misfire or over rich condition . a misfire will cause the bucking and jumping. a bad injector will over rich the system also have checked with scanner a clogged converter will set the light on.
1helpful
2005 Convertible PT Criser, Turbo
Emission devices in vehicles sold in the US are covered for 8 years. This is federal law. Talk to the service manager at your local dealer. A misfire will cause emissions to go up so it should be covered.
1helpful
2answers
Have po301 code 1 cylnder misfire whats the
anything from bad wire .plug or fuel delivery problem to cylinder 1pull plug and c if fouled -also test wire for break
3helpful
2answers
Engine light on
They are still looking for a cause because it isnt misfiring right now or because they cant find the cause of the stored misfire codes ?
If it is misfiring right now and they cant figure it out then perhaps you should find new mechanics !
I have seen a lot of bad coils on the PT.
Misfire is usually caused by spark plug wires first, spark plugs 2nd, and coil third.
If it isnt misfiring now, spray down the wires with water. If it misfires after that replace the spark plug wires and spark plugs and try again.
If it still misfires then the problem will likely be the coil.
1helpful
2005 pt cruiser... it sputters and won't idle well
That is the first thing i would suggest you do. Replace all the spark plugs and the plug wires. Those 2 things are the most commen thing that cause misfires.
Top Chrysler Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Chrysler Expert? Answer questions, earn points and help others
