SOURCE: Datamax problem
You probably need to adjust the leveling cam if you have not done so already. This is the green thumbscrew near the print mechanism.
SOURCE: printer not lining up and display doesn't work
You can adjust the display contrast by pressing and holding the MENU key for 10 to 20 seconds to modify the LCD contrast level.
SOURCE: Won't print labels
Ended up being the heating settings - they were to low, so when I hit print...it would spit out a label but nothing would be on it.
Problem solved!
SOURCE: Regarding Datamax E-4203 - Won't print
Check to see that the label sensor is over the gap in the label. It is just under the head on the right hand side.
You might also have the unit configured incorectly. If you go to the Datamax site, you can download the printer config program, It is easier to use than trying to push the buttons in the correct order to configure the printer.
Also use at least a 6" long label, and print the config file to see if you are set correctly for gap mode if using die cut stock.
http://www.datamaxcorp.com/software/e-class/
There u go!
Manuals, drivers, firmware and utility for the E-class,E-4303,E-4204 and E4304
Good luck
Nic
