Unable to get string stuck out of spool head
SOURCE: can not remove spool to replace string
If it's like my Ryobi, the alignment arrows are for feeding in string, not removing the spool. When aligned with the arrows, you should be able to insert two pieces of line into opposite sides of the housing. The ends of the line will come out of the spool next to a tiny hole. Put the end of each of the two lines into the holes, then pull the two lines from the outside. This will lock the ends of the line into the tiny holes in the housing. Now you can turn the housing by hand to wind the lines onto the spool. I think it will take about ten feet of line (on each side).
Alternatively, spin the bump stop out of the assembly. This holds the spool in, so when the bump stop is removed, the spool comes right out.
I hope this helps.
SOURCE: Spool is stuck
Have you tried using vise grips to get it off. Next time put neverseize on it.
SOURCE: string wont advance from spool
sometimes thows automatically spool go bad
afterwhile.get a new one
SOURCE: the string in the spool of the weed eater is stuck
Sounds like one of the loops is over the one being fed out. Does that make sense? I hope so. If one of the windings of string is over another, it makes it hard to unwind. Maybe if you were to put on a glove and really pull on the string, it would start to unwind. Other than that, pull the head and check the string. Good luck...Lee
SOURCE: I am tryinng to remove
These are REVERSE THREAD - this should do it - turn it the other way.
Gary @ Fix Ya
