Machine: KFX 700- EPI clutch kit, Dual DMC alien exhaust, dyno jet kit.-- Seems machine is running like **** after i fixed from rollover. after 10-15 min after warmup when u let off the throttle and/or come to a stop you need to flutter the throttle a few times so it doesnt die and idles right. Had the Carbs check out...was backfiring thru rear carb and they found the crossover pipe was crushed by airbox and that solved that problem. ive tried an after market ignition but that really makes it run bad when the machine warms up. New Plugs. Shop said was kidda running rich by looking at old plugs. Please help, what is being overlooked??
K&N air filter was freshly cleaned, petcock is undamaged, and choke seems to be fine and working properly. Even though I use a 90 or greater grade of fuel is the ethanol screwing with it, smells like im very rich when its running though
no i dont...
