Hi , you have probably expired the battery life out of the radio [ they have a recharge battery life ] but all you have to do is replace those recharge batteries with new recharge batteries and your as good as new
I will give my info here and say that I -was- able to replace the battery in my Freeplay S360.
I purchased two of the 2/3 AA rechargable NiCD batteries and soldered them together. Then I rewired it into the radio and voila! It works!
Total cost: about US $4
Total time: about 20 minutes
Now all I need to do is remember to use the thing every month or so, just to keep the battery in good condition.
Columbia FRS22-WH L301 Li-ion 3.7 Volt 500 mah Rechargeable Battery
Battery code L301
1 7/8" by 1 5/32" by 1/4
Contacts are on the flat side - 3/16" from the wide edge and 1/16" from the long edge
Brand New Original Pair Battery For FreeWalker RD-810, RD-820, RD-008, RD-820 Features ***Brand New Original Pair Battery For FreeWalker RD-810, RD-820, RD-008, RD-820*** Best replacement battery for FreeTalker Walkie-Talkie RD-810, RD-820, RD-008, RD-820. Crafted with latest Lithium-Ion technology, it is intended to delivers long lasting talk times. This Li-Ion based battery provides power in a thin, short and light package, fits the compatible Walkie-Talkie model perfectly. It has power capacity of 600mAh, which allow you constantly talking for 3 hours. standby time up to 3 days. It is absolutely an ideal choice that you won't be sorry for getting.
Features:
* Battery Type: Standard Li-Ion Battery(Model: RD43048) * Capacity: (600mAh) * Voltage: 3.70 V * Talk time: 3 hours. Standby time: 3 days. * Color: black * Dimension(L*W*H): 4.6x3x0.5mm * Weight: 0.015Kg
Compatible Model:
RD-810, RD-820, RD-008, RD-820 FreeTalker Walkie-Talkie
Solution #2 is correct. My Baygen Freeplay radio was running fast and mine had a broken belt. I could not find a belt on eBay. After hours of searching the internet, I fond a replacement belt at http://www.kenselectronics.com/lists/belts.htm I have the older large Baygen Freeplay radio without solar power and this is the belt that fit my radio... AV-SBS9.5 Replaces SBX9.5 & 1407-36 & SCX9.5 square 9.5 x .047" belt, Baygen Freeplay. Just search the website above... they also have a second size Baygen belt that might fit the newer Baygen Freeplay radios???
