Heating & Cooling Logo
Anonymous Posted on Jul 17, 2013
User manual how do i clean the fileter and drain water from it
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Master 102,366 Answers
  • Posted on Jul 17, 2013
Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10444161
Points
622693
Washer won't drain, E:13 code flashing
From user manual:
Indicator light "rinse" is lit and display is flashing "E:13" with no water remaining in the drum.
For some reason drain pump is blocked.
Clean the water drainage pipe and/or drain hose.
Dado
F& P bottom dishwasher draw won't drain. Top dish draw draining fine?
Excess water in
the DishDrawer
Drain hose(s) bent or
kinked.
Straighten the drain hose(s).
Blocked filters and/or drain
hose(s).
Clean the filter plate/drain filter. Unblock
the drain hose(s). Refer to the user manual
E1O DISPLAYED
The other E10 fault is a clogged drain pump. Instructions to clean and free this are in the user manual obtained here. http://www.aeg.co.uk/Support/Manuals/
Peter Kay
Siemens SI14-44 washing machine is error coding F:18. something wrong with the emptying of the machine.... is the filter blocked? is so where can you clean out the filter?
check in the manual for the error code most of washing machine if the error code is in users manual its means its only minor problem,but if the error code is not in users manual its means you need to call an service technician to not waste your money or time if you do by your self.
F:18? if this error is for water stuck?
for the automatic washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.
417 44152400 21 code reads e63 and machine not draining properly
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Not cleaning well. appears food and water not draining during cycle. Is there a way to clear drain?
there shouldnt be much food in it to drain?? consult manual for how to access pump for cleaning it is user serviceable.
Paloma water heater error c7 13
I have a code showing C7 13 the heater runs for about 2 to 3 mins then shuts off. Any suggestions?
Washer does not spin out and drain water. what could be causing this?
Possible pump failure or maybe just drain filter blockage , refer to user manual , clean filter , replace and re-try N.B. If machine is still full of clothes and/or water you will need to remove this first or you risk flooding your kitchen floor.
Filet folded & overflowed. Now coffee maker will not make coffee
Clean your coffee maker with vinegar or as the manual instructs no fewer than 3 times per year, at least 3 times back-to-back if you haven't been doing so regularly. The heating element may be overheating due to hard water deposits, triggering the end-of-cycle shut off.
Won't drain water out?
Regardless of the brand, all dishwashers operate on the same principles.. in this case you said you checked for clogs and there are none..however.. have you checked the fileter screen for the drain, the hoses to the pump, the pump itself, the exit hose off the pump, the drain hose coming from the dishawasher to your house drain and is your house drain restricting water flow? Also.. is the pump actually operating at any time? These are the funadamental items to check..any one of them can cause your dishawasher to not drain properly. Hope this helps..
Top Heating & Cooling Experts
Paul Carew
john h
