Hello and Welcome to FixYa!
Sir If you want to unlock
your phone lock code please go through the following procedure. This
procedure will tell you your Unlocking lock code without flashing and
resetting of any kind!
Follow these steps;
Open this link and download the software for your Spiro PLEASE CLICK HERE
Follow the onscreen instructions to install the software.
Once installed, turn off the mobile and remove
the battery. Now reinsert the battery and insert the cable (DCU-60
thatcomes with the box) while holding the 'c' or '@' button on your
mobile.
Your computer will detect a new device and install it.
Once installed please unplug your mobile, remove the battery. Now reinsert it.
Download xs++ from here
Extract this file and run XS++.exe
In XS++, click Connect.
Hold 'C' or '@' key on your phone and then insert the USB cable.
u can get some information about your phone when it's connected
click or tick GDFS at the bottom.
Then click Phone Lock, it will show you the code on right hand side. Note that code.
click Settings at the bottom, then Disconnect.
unplug the USB cable, remove then reinsert the battery.
You are done, enter 0000 or the Noted one (In the 3rd last step)
You have done, This procedure surely helps in getting Unlock Code for Sony Ericsson Mobiles.
But if you find this process little bit tough and unfortunately u don't get the unlocking by this then other option is to get unlocking code online
GO TO THIS SITE
Here select your country and the network and order the Unlocking Code, Though its an little bit expensive but Its the only site which provide you correct and timely unlocking service,
It take 3 to 10 working days to provide you unlock code. when u will get unlock code, follow the given procedure
Do not enter any wrong unlock codes on your Sony Ericsson W100i Spiro
mobile phones. If you enter over a certain amount of wrong unlock codes
on your Sony Ericsson W100i Spiro mobile phone, your phone may get hard
locked and sometimes become unusable.1 - Switch ON your Sony Ericsson W100i Spiro
without any SIM Card,
2 - Press the
left arrow key/button
once,
3 - Press the
button * twice,
4 - Press the
once,
5 - The message "Personalize with MNC2" will appear, (or you will have
displayed an unlock menu, select the lock you want to unlock)
6 - Enter the Unlock Code.
Try first method if you get your unlock code by this then there is no best option for you except it, Its the free procedure to get unlock code, But if u don't able to do this then to unlock adopt second method.
I hope this solution surely helps you.
Let me know if you have any confusion.
Your words of Appreciation and Rating will be esteemed.
Thank You for taking my service.Concerned: Muhammad Uzair Team: FixYa
