double posted, now with 360, 5.9L V8 fact.
great.
and has no such sensor.
its a CARB car
with ICM , spark magic box. , NO ECU /PCM brain in car
there for no CKP sensors.. sorry?
if you dont know what is there, photo it and post it
so others can see what is missing or wrong, from factory day 1 build.
i google for you
rockauto shows no such part in 360
alldata.com same
hell. even the 90s the same.
see it here.
all schematics
if engine wont start. even with test fuel, check spark
see the spark section below, under ignition.
http://oljeep.com/gw/elec/GW_wiring-1990.html
the distributor has cam sensor. not crank.
it called today, CMP, cam sensor
this sensor sends signals to the ICM the ICM then makes spark
buy driving the coil,
the CMP is more like Points, simulation, and lasts near for ever.
the 89 4L has a CKP (crank sensor) and is know to fail on brand new cars. (you need to tune it to make work , back in 88/89) at flywheel.
ask me how in know./././??
360 spark
CMP >>>>> ICM>>>> COIL>>> Dizzy cap>>> spark plugs.
this is the chain of events.
the DIZZY does the ADVANCING with ICM. totally. on this car.
What is the condition of the plugs and wires, and are installed correctly ? Is the timing correct ?
