Webroot AntiVirus with AntiSpyware & Firewall: Windows Logo
Anonymous Posted on Jul 16, 2013
Possible virus Unable to launch spysweeper or the internet.
Catherine
Level 2:
New Friend:
  • Expert 95 Answers
  • Posted on Jul 18, 2013
Catherine
Expert
Level 2:
New Friend:
Answers
95
Questions
50
Helped
19116
Points
145
Can you tell me the detail of your question ?
Slow speed
If you do not have sufficient anti virus / spyware software then you most likely have a virus.
Clarify with what antivirus you have installed if any...
If you don't have any then I would suggest buying one of the following
Bit Defender Internet Security or Antivirus Pro http://www.bitdefender.com/2011/en/internetsecurity2011/?gclid=CLjrkuuU-6kCFQQCbAodJX-fZg
Webroot Internet Security or Antivirus with spysweeper http://www.webroot.com/En_US/consumer.html
or Kaspersky Internet Security http://usa.kaspersky.com/store/all-products?c_id=GOO1673628
Once installed make sure to update the software and run a full scan If you are unable to update the software Reboot the computer and press F8 until you get a menu Select "Safemode with networking" You should now be able to update the software and run a full scan
Webroot spysweeper with antivirus won't open anymore
My advice: uninstall it, and install the _free_ anti-virus software from Microsoft: http://www.microsoft.com/security_essentials
which does _NOT_ require any "key".
1helpful
How do I reinstall or restore the Spy Sweeper Engine? It is damaged or can not be connected to.
1) Click on START
2) CONTROL PANEL
3) ADMINISTRATIVE TOOLS
4) SERVICES
5) scroll down to "Webroot Spysweeper Engine" and RIGHT-CLICK
6) select PROPERTIES
7) click "START" service
Now try opening/launching Spysweeper. It should now work.
IF NOT.....set the "start-up type" to MANUAL, START the service
and try again.
Hope this will help you...Thank you....
Cant update my spysweeper
Sometimes anyantivirus is reported as a virus code for another antivirus,
  • If any other antivirus is installed, please uninstall it.
  • if your spysweeper is expired, please obtain new version
  • uninstall spysweeper, clean registry, and reinstall it.
  • use proper authentication, sometimes administrator installs the SW, the user is not able to update it.
Goodluck
Zulfikar Ali
1helpful
Antivirus suddenly stopped Working
Download Malwarebyte's Anti-Malware, Ad-aware and Spybot, and run them all (one after another, not all at the same time) to see if you're not infected by some spyware.
Also run some anti-virus, like Avira - or even the online Trendmicro housecall (http://housecall.trendmicro.com/housecall/) to check for viruses.
And do that if possible disconnected from the internet.
If nothing is picked up by those programs, then you can try a system restore to a point where everything worked. Be sure to backup your data first, since you can loose some data with System Restore.
Exception
Hello,i have been reading your problem and i have a simple sollution..... simply launch the start menu,then "all programs" then hover over the text "start up" then drag the spy sweeper app into the start up section.... then simply restart your pc!
thanks for your question,
have a nice day!
Unable to Validate Game Version
Two causes for this error meassge either you are not running the latest version of World of Warcraft, or your game files have been modified.
It is possible that you have a virus or program which is modifying files on your computer. Scan your computer with an updated anti virus program to make sure that your machine is clean. Then make sure you are launching the game using Launcher.exe
If none of the above helps they are a few repairing tools that might fix your game, you might want to check "Fix Wareout".
Good luck.
2answers
Internet
Your Trend Micro will only handle viruses, for website access, it's the SpySweeper. Try disabling SpySweeper and surf, if all goes well, you just need to configure SpySweeper.
Uninstall
use Ccleaner software to remove spysweeper software. link is below.
http://www.ccleaner.com/
2answers
Webroot Spyware Question
Hi kn21_83
Your SpySweeper program functions by viewing incoming programs requesting access to your computer, referencing them to a built-in definitions file that updates regularly, and granting permission or red-flagging potential spyware programs. So, the definitions file is very important for the program to work properly.
I recently had a customer's computer display the same error message, and the way I was able to work-around it and make the SpySweeper program work properly was to uninstall it completely, ensure that there are no other anti-virus programs that might interfere with SpySweeper's install (if you have norton for example, manualy disable it for the duration of the install), and download the most current version from the internet rather than your disks that came with it.
Now, there could be other things involved, such as a malicious program interfering with how SpySweeper functions. In that scenario, restoring your OS is usually the fastest method of restoring functionality to your machine. Hopefully it is not a virus infection, but if you run out of ideas to resolve the issue a restore is a simple fix that guarantees success.
Top Webroot Computers & Internet Experts
Mike 'H'
Mike 'H'
Level 1 Expert
ADMIN Andrew
ADMIN Andrew
Are you a Webroot Computer and Internet Expert? Answer questions, earn points and help others
