Are rheemglas rp5044m hot water heaters actually glass lined
SOURCE: Hot Water Overflow
Do you have an expansion tank tank in the line leading into water heater? If not what is happening is that the water is no longer allowed to go back into the city supply. You said that you had turned it off while you left so the water heats up and has no place to go so the preasure/ temperature P/T valve opens and lets out the excess water from the expanded supply (heater water) that has no where else to go. It used to be that the extra expanded water just backed up into the supply pipe and back into the main. That is no longer possible in most places by the National Plumbing code. The answer may be to install the expansion tank into the incoming line. You can see then now at all hardware stores where water heaters are sold.
SOURCE: Rheem small 6 gallon water heater vibration/noise
If the water heater is working fine than I would not worry about the function of the water heater. What the problem may be is that some of your WATER LINES HAVE MOVED, AS THEY WERE NOT SECURED PROPERLY. The sound you may have heard was the Copper or PVC(Plastic) lines just getting back comfortable. I Suggest checking that your water lines are secured about every 3 or 4 feet with the proper ancjhor....Metal for metal pipe, copper for copper pipe, etc. Sometime as in my house, pipes are run through a hole drilled through a stud or a piece of wood, usually when hot water is run through this pipe. You can here an expansion of the water line interacting with the pipe expanding, if the hole in the wood was not drilled big enough......Experience of remodeling a very old house.......Joe
SOURCE: flush Rheemglas Fury 22VR75 yearly-increase life of H2O heater?
yes you will increase life if you flush sediment yearly
SOURCE: I have a Rheem Warrior Glass water heater for a
Probably a 40 gallon one ... if it's electric you probably have a burned out element. (easily replaced)
SOURCE: We have the Rheemglas standard model #81V52DT-C
Hello, The cold water dip tube is busted.How old is the unit?A plumber can make a new one but might not be cost effective.
