No diagrm in engine bay dayco doesn't show one. seems to be 1 extra idler. very tight & confusing engine compartment. oh yeah 2.4
2.4 ? Are you sure it's not a 2.5 ? also will need to know the year and possibly if it's like a JLS, JLX, JLX Plus, LTD JLS 2WD , JLX 4WD.....There are a number of models and want to be sure I am able to give you the correct diagram. You can reply here or feel free to email directly at [email protected] with the correct information. Also you may want to try autozone.com. Sometimes they have the diagrams after you add your car and go to the repair help tab.
Testimonial: "2010 bought belt for 2.4. Tensioner a/c ps on drivers side,, idler alt w/p passengers side. 1 idler across top,dual cam. 4wd auto."
SOURCE: Serpentine belt routing
Here you go.. I looked up the same belt you did, it should be right.
SOURCE: I need serpentine belt routing for 1999 Jaguar XK8
This is a view of the correct belt routing ..
SOURCE: belt routing guide
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
SOURCE: i NEED 2005 mazda6 Serpentine Belt Routing
There are 2 engines for your Mazda 6, a 2.3 and a 3.0. Below are both diagrams:
2.3
3.0
Kia_Sedona_2002-2006
Accessory Drive Belts
Fig. Accessory serpentine belt routing-3.5L engine
Fig. Accessory serpentine belt (A) routing-3.8L engine
Inspection
Inspect the drive belt for signs of glazing or cracking. A glazed belt will be perfectly smooth from slippage, while a good belt will have a slight texture of fabric visible. Cracks will usually start at the inner edge of the belt and run outward. All worn or damaged drive belts should be replaced immediately.
Removal & Installation
