I have an asko T712C dryer. When I try to use it, it stops after a few minutes and I get the error code f1 but the machine has been set up for automatic drainage so i have no way to drain the condense water container cause there isn't one!! what do you think might be the issue??
SOURCE: My t712c asko dryer is making some loud noises.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
nfgnc
There
can be many reasons why your dryer will not start or turn...
The
most common causes are the belt breaking or jumping off, or the motor
going bad...
Here are a couple of tips that I wrote will help
you to figure out why your dryer will not run...
Dryer Repair
- The Dryer
is not Turning
Dryer
Repair - The dryer
will not start
heatman101
