Question about Asko T700 Electric Commercial Dryer
How to Replace the belt for a Asko T700 Dryer?
Posted by John Thoreson on
mark799
    Problem Solver:
  • 9 Answers
I have a T760, and the way I do it is to take the top off (3 screws in the back and slide it out from under the front lip), take some pics of the wiring so I'll know where they go (they're marked, but pics still help), and take the back off (perimeter screws). The drum bearing is mounted in the back, so I have to tap the drum shaft thru the bearing (take the washer off and put the nut back on so it is flush with the end of the threads). Asko has a special tool to hold the drum in place while the back is off, but I made one out of a coat hanger (a hook on one end to hang on the lip of the drum, bend a couple of right angles to fit thru the holes in the front panel, make it before the back comes off). The real hassle is holding the drum in place while reinstalling the back and the tool does this nicely. The belt has a spring loaded tensioner, make sure the wheel and bearing are ok, put it back together, and you're back in business...
Posted on Feb 27, 2014
5 Related Answers
Anonymous
SOURCE: Asko T700 loose belt, access from front?
to change out belt- remove top panel from 3 screws in back along top edge. Then remove the 2 top and the 2 middle screws along the sides of the back panel. You can leave the 2 bottom screws in the corners in place. Now seperate the drum from the front plate just enough to slide the new belt down and over the drum. push drum back into place and set new belt back onto tension roller and motor spindell.
Posted on Jun 18, 2009
Rotu
Douglas Henry
  • 175 Answers
SOURCE: ASKO t700 dryer thumping sound
usually whin you get one thump (or a quick double thump) you have a dent in the roller surface of the drum itself. Easiest way to check this is to unplug the unit and take the top off by removing the 3 torx screws in the rear, then lifting the top off. Once the top is off look at the very front edge of the drum as you rotate the whole thing by hand. If you see any irregularities on the surface, thats your problem. If you see nothing it could be a bad motor or roller, but its unlikely if its happening in the same place on the rotation evry time. What has usually happened with dents in the surface of the drum is that the unit was set down too hard (or dropped) and the wheels it rests on dented the metal they ride on. If thats the case the only solution is to replace the drum or live with it .Good Luck!
Posted on Mar 25, 2007
Anonymous
  • 15 Answers
SOURCE: Noisy, wobbly Asko dryer
This could be the front drum support wheels. They are made of rubber and I just replace one that had broken up, causing the machine not to spin at all. (I replaced both while I had the machine apart as I'm sure the other one is at the end of its life too).
To get at it, I had to take the top and the back off of the machine (removing all screws) and then unhook the belt so I could pull the drum out enough to see the wheels. The wheels are bolted to the front plastic with a nut situated inside of it, so you will have to loosen that to hold the nut in place.
You'll need some torx bits of various sizes to do this job and reassembly takes some jiggling to line everything up. Took me about 2 hours all together.
BTW - if it is the belt , it is virtually the same procedure, but if your drum is rotating at all, I doubt it is the belt.
Posted on Apr 18, 2009
mek363
Mat Kramer
  • 20 Answers
SOURCE: I need the wiring diagram for an Asko T700 dryer.
I'll add the diagram that was inside my Asko T700 to the documents section.
Posted on Aug 16, 2009
Anonymous
  • 10515 Answers
SOURCE: how do I replace the belt on my Asko T761 dryer?
How to install a belt on ASKO dryer
Belt Type: Flat belt with ribs
Installation Notes: Ribs go against drum
You could Refer to :-
http://fixitnow.com/wp/2006/05/08/asko-t700-dryer-wheel-drum-and-belt-replacement-instructions/
It would be a Generic one but would help you.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Mar 11, 2010
The drum stopped turning on our Asko t700 dryer even though the dryer motor works fine so it runs and blows air but will not turn. Both of the fuses seem fine and as I say the motor and everything else is...
the belt is broken, here is a thread:
http://applianceguru.com/forum2/2043.html
here is a manual:
http://www.ajmadison.com/ajmadison/itemdocs/English-T711-721-731-761-781_UCG.pdf
Hope it helps Tim
I have an ASKO T700 dryer. When I turn it on, it makes a high pitched squeak. If it's on for longer than a minute, I can smell a burning smell. Any suggestions?
you got a roller or belt idler not turning and burning the drum belt. you have to take the dryer apart and find the problem. if you need to lubricate a roller or idler use mineral oil or roller oil, do not use wd-40 or 3 in one.
2answers
How do I replace the belt on my Asko T761 dryer? Do I go in thru the front, the back? Are there instructions on-line for belt replacement?
Hope i helped you.
Asko T700 dryer does not heat up, and start button does not work unless held down.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Noisy dryer with long dry time
check to see if the fans are loose if so replace them this will also cause poor drying time.iI find its better to dismanttle these dryers and check the rollers,belt and jockey pulley at the same time.they look hard to work on but they are easy just take you time theres generally no wires to undo.
2helpful
2answers
I think you must replace the belt and the tensionarm. It MUST be done from the backside of the machine... Remove the backpanel, and the drum, change the tensionarm, and put the drum into the machine again. Put on the new belt, and mount it together again. Be careful for sharp edges! Hope this helps :-)
Replacement part for Asko Dryer T700
Call Asko and order it there. Cant imagine that it is a expencive part. I only have the Norwegian partnumber.
Open Questions:
See all Asko T700 Electric Commercial Dryer Questions
Asko T700 Electric Commercial Dryer Logo
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Ekse
Are you an Asko Dryer Expert? Answer questions, earn points and help others
