Every time I click on my user name my desktop screen appears for a split second then it says saving settings and goes back to the user screen.
Unfortunately when I experienced this issue not too long ago the only fix was a repair installation (also known as an in-place upgrade).
Read this KB for more info:
http://support.microsoft.com/kb/315341
Hope this helps!
I think this is a work of a virus program. The aim here is that EXPLORER.EXE file is the one getting opened when you login. As soon as you open the file, "Log off" command goes up and u return to the same logon screen. Try this, Boot you system> keep pressing F8>choose "Safe mode">now try loggin in to the OS> if it enters, press ALT+CTRL+DEL , end the process that you feel it isnt appropriate > go to start, run , type "msconfig"> go to startup tab> and uncheck all> reboot the system..Hope this helps
1 Insert the Windows XP CD into the CD drive, and then restart your computer. If the messagePress any key to boot from the CD... appears, press a key to continue booting to the CD.
2 In the Windows XP Setup screen (Figure 1), press to set up Windows XP.
3 In the Windows XP Licensing Agreement, read the license agreement, and then press to scroll through the agreement.
4 Press to accept the terms and conditions specified in the license agreement. The partition screen is displayed. depending on your computer configuration, the partitions listed may include a PC Restore partition (2.7 to 4.75 GB) or a MediaDirect (1.2 GB) partition.
5 Highlight the largest partition and press .
If you are prompted to format the partition, use the up or down arrow keys to highlight Format the partition using the NTFS file system (Quick). Press or , if applicable, to format the partition. In cases where the drive must be checked for errors, select the Format the partition using the NTFS file system option.
Setup will format the drive, if necessary, then copy the files needed for installation. This process can take several minutes. Once done, Windows will restart the computer to continue Setup from the hard drive.
6 After the computer restarts, Setup continues with a graphical user interface (GUI) in the classic Windows theme. In this stage, you are asked to input information to personalize your installation. Your screen may blink several times during this process, which is normal. The information to input, and the order it is provided, is shown below:
Setup will finalize the installation and should complete within 30 minutes of this point. Once complete, the computer will restart.
7 After the computer reboots, the newly installed operating system will attempt to configure itself for your detected devices, however many of your device drivers are not yet installed. Use the following to finish the configuration and prepare the computer for driver installation:
I tried booting it up in safe mode bit it did the same thing. Any other suggestions?
where can I get a repair installation?
