Windows closed and you boot the system unsafe mode while the system files are loaded it asks you to wait . This is while loading the drivers.... Next thing is a black screen. Any idea what is wrong?
Restart the computer. Hit F8 at the start-up. Please choose Last known good configuration using UP and DOWN key.If not fixed: Repair Windows XP using Windows XP disk:
http://www.windowsreinstall.com/winxppro/sp2sp3installxpcdrepair/indexfullpage.htm
SOURCE: 6480iPTD notebook- boot problem
Video drivers not loaded for that laptop, in safe mode reload the video drivers.
SOURCE: I have an Acer Aspire 6930 it loads with a black
Check your BIOS and ensure your installed amount of RAM is correct. If not you have a bad stick. If it is correct, and you have more than a single stick of memory installed, try removing one and restarting, then the other. If there is a bad stick and it's not obvious this will help you find it. Also check your processor status while you're in the BIOS.
SOURCE: Windows Won't Load
Same thing happened to me. Looks like your windows install is damaged. My advice, do a fresh install of windows. You won't lose any of your files, but you will have to reinstall most of your software and drivers.
SOURCE: System shut down during update installation now
you need to run a nifty little program called Spinrite on your laptop. You can download it via BitTorrent HERE
you will need to use a program to burn the ISO image onto disk and make it bootable. I use PowerISO . It is very easy and straight forward. You can download it HERE (use the name: Dr.Upload
serial: SKSIP-7AIX1-8YWEZ-U197K-T88IE ) to remove restrictions.
Open the iso file using PowerISO. Now we have to make it a bootable disk image. Spinrite comes with FREEDOS instaled, but most laptops don't like using it.
Follow directions here on making a bootable image.
after burning your disk boot your system up with the cd. when you get to a prompt , ie C:\\ you will need to change it to your default cd drive mine is E:
after changing the drive letter type SPINRITE
the program will start - follow onscreen directions and change scan level to 5. after program finishes reboot after removing disk.
should run like a new pc with no Loss of information.
SOURCE: My Compaq presario f572us notebook screen turns
Why will my monitor not stay at 1024 x768 when I change it on tthe control panel. I have Vista.
