To fix the shoulder the buttons, they are not physically broken, they are TEMPORARILY electronically broken. This problem can be fixed if you put your charger in it then wait about a day from playing it. It usually works, if your button slowly works in about 10 min its fully working, the other shoulder button may begin to have soe latency, this is normal. Just make sure you don't playing games like "Kingdom Hearts 358/2 or any zelda games in which u may use the l or r buttons alot
The problem is that your son dropped it. This damages both the inside and outside of the DS. I would suggest contacting your nearest video game store to see if they can fix it.
blowin F1 or F2 fuse or both inside your nds. can be fixed by runnung a bead of solder the blown fuse so it bridges the fuse (idealy you would replace fuse but its very tricky) first of all if you have a multi meter check the fuses before soldering them. anyway i advise not to use the homebrew card especially on your nds when you bridge the fuses as once the fuses have been bridged there is no saftey shut off to stop more sever damage. oh by the way just youtube F1 and F2 fuse location to find out where they are. oh and use a 15watt solder iron to be on safe side (less chance of overheating any components near fuses when soldering). its not that hard to do really (i did 2 of them with a gas solder iron due to me not having a 15watt iron) also replaced cracked screens. my next job to do is replace a L2 inductor on a friends nds (symptom for this fault is nds charges but will not power up, not even a blink of green light) for anyone who has this symptom its the L2 inductor thats broken away
Yes, this can be fixed. You will need to replace the top LCD screen of the NDS, as the cable attaches directly to it. The speakers will need to be soldered to the new top LCD screen, as the top replacement screens usually do not come with speakers attached to it.
Your on/off switch is broken and must be replaced by a Nintendo repair Service. Also if I read it correctly your DS Lite housing is broken and also must be replaced.
Its possible though sometimes it is expensive so dont worth the work.
-Top screen broken: you can buy a replacement and carefully do the work by yourself with the help of a guide (youtube have many) and some tools (3 winding screwdriver is the less common though not much). The foil data ribbon can be bought separatelly for the original NDS though the new NDS lite have it soldered and very difficult to work.
-Broken plastics: a broken hinge means you need to buy a replacement shell. Anyway buy a complete shell from a DS modding shop or take parts from a non broken plastics DS (water damaged one may be good) in a place like ebay. You would be lucky if you find a non broken screens and good plastics DS for parts.
At the end you may be over your repair budget and not only that, you would be very near to buy a new unit with this money. Each one make its own choice.
If you are confident in taking it apart, just compare the L button to the R button, you should see what the problem is. And since you already have it open it will make it easy to replace what needs to be replaced, which is probably just the L button itself.
Hello ! thank you for the response.. yes all other keys work,
