Check all the connections with an analogue multimeter set to 12 volt dc.You should get fsd at all points. There is no doubt that you have an intermittent fault on the wiring.However, there is a slim possibility that this fault may, in turn, have caused damage to the clarion.If you cannot find a fault on the wiring, then consult a repair manual (available to download) to see whether or not there is a fuse inside the clarion. If there is one fitted, check that to see if it is blown. If thate above does not sokve the problem you are welcome to email me for further help on
[email protected]. But I think fokkowing the above advice shoukd solve you lack of sounds in your car. All the best
