I want to get rid of the default messages set in the clock.....such as "Are You OK?, Happy?Happy!, etc. I just want to be able to display my own messages which I have entered plus the date, day and time. Any suggestions, as I don't have a user manual?
If you are experiencing this problem, continue as normal to print your clock then choose preferences and ensure your printer settings are ok and that it is set to print to the dvd/cd tray, then proceed to print your clock.
If you are still experiencing problems Try Solution 2..
Instead of changing your printer settings through Clock Designer, change your default printer settings. Go to the control panel in windows and open the printers section. Find the printer you are using (Actual screen shots will vary depending on your version of windows and printer)
To set time go to settings & tools push ok.Choose tools then ok.Choose world clock then ok.Choose north america or whichever country to show time then choose ok.Use arrow keys to select state in your time zone then push key for set dst,choose yes if correct then choose ok.Setup complete and next call will set correct time if done correctly.Wrong time zome will delay text messages.
I
bought a Caixing CX-2158 led digital clock in Thailand and there aren't
any instructions to operate it eg; set time alarm etc. Can you help
please? Philippines Thank you in anticipation.
I have the same clock and had the same problem. My clock was a demo and had no instructions with it. Here is the solution: 1. Pull out the battery and wait 10 seconds then replace the battery. The satellite symbol should start flashing after a few seconds. 2. Put the clock outside or in a window sill till it updates. This could take a couple of minutes. 3. Press the Mode button once to enter programming mode. 4. Press the Adjust button as many times as needed to toggle through the time zones. 5. Press the Mode button once to exit programming mode.
Press the mode button until you find the setting for 24 hour or 12 hour setting. (It is likely that the message will be abbreviated because of the limitations of the display, so some interpretation may be needed.).
You change the setting by pressing one of the other buttons on your watch - some experimenting may be needed.
1)Press "SET" button for more than 3 seconds until digits of certain area blinks.
2)Press " ADJUST " button to increase digit reading value of year, month, hour, minutes...etc. of the blinking area ( Note: all adjustments are towards increasing increments only. Just cycle if accidentally past the required setting )
3)Press "SET" button once to jump from one area of adjustment to the next...example from calendar to month to hour to minutes to seconds....etc.
4)Press "mode" button to confirm all settings
5)Finished
Set the Clock
You must set the clock once so that the
system announces the correct day and time
with your messages. After this, if you
subscribe to Caller ID, the system will
automatically reset the clock each time new
call information is received.
Press Pto exit at any time while
setting the clock.
1 Press and hold Cuntil the Message
Window displays C, and the default day
is announced.
2 To change the day setting, press and
release ror auntil
the correct day is announced.
3 Press and release C. The current
hour setting is announced.
4 To change the hour setting, press and
release ror auntil
the correct hour is announced.
5 Press and release C. The current
minutes setting is announced.
6 To change the minutes setting, press and
release ror auntil
the correct minutes setting is announced.
7 Press and release C. The current
year is announced.
8 To change the year setting, press and
release ror auntil
the correct year is announced.
9 Press and release C. The new day,
time, and year are announced.
To check the clock, press and release
