KitchenAid 24 in. KUDI01IL - Multiple Color Free-Standing Dishwasher Logo
Posted on Mar 24, 2009
Hotpoint dwt10 not working rinse aid light flashing
Some liquid is still in the bottom
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 15, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
475
Points
I have DWT10P dishwasher.It is displaying two rapidly fashing E lights (Fast & Delicate )wash cycle.Can you tell me what its mean?
3answers
Where to put rinse aid in cdw10 dishwasher
Rinse aid makes dishes sparkle more as it improves their drying. The rinse aid container is situated on the inside of the door. You should fill the rinse aid container when indicator lights up on the container and the rinse aid indicator light on the control panel flashes. You can use simple vinegar as a rinse aid (white is best but apple or malt is fine).
Adding rinse aid.
To open the dispenser, turn cap anticlockwise. Take care when you pour in the rinse aid to avoid it overflowing. You can regulate the amount of rinse aid used by the dishwasher, move the adjuster which you will find under lid. The amount of rinse aid needs to be increased if the dishes appear dull or you can see circular stains. The amount of rinse aid needs to be reduced if the dishes are sticky or see white streaks.
You can choose from six different positions. It is normally set to 4.
1helpful
Does powder go into "rinse aid" recepticle, or
ALL DISHWASHERS i'VE HAD USES A LIQUID.
My dishwasher will start any cycle then half way
The touch pad has gone bad. Common problem with the GE made dishwashers.
May 12, 2010 • Dishwashers
9helpful
2answers
Flashing lights on Hotpoint FDL570 Dishwasher
I had an identical problem with the salt and rinse aid lights on the left and the drying and end lights on the right flashing shortly after switching the dishwasher on. When I pulled it out, as this was the only way to look at the pipework, I noticed a big kink in the water hose. Removing this and obviously sorting out the flow problem has resolved the issue.
Mar 20, 2010 • Dishwashers
Greetings from Downunder, i have a HDWSE12 dishwasher Rinse aid light flashes all the time and it won t go. I put dish liquid in rinse aid container - still flashes. Don't normally have to use rinse...
the rinse aid compartment has to be one of the biggest things in your unit. it helps with drying process or you will have wet dishes, helps with spots, and also with the cleaning process, this is what you can do . add jet dry or rinse aid not soap .fill compartment then close door ,then raise and lower door 3times then open the compartment door and add more repeat this process until you cant add anymore. this will pull all of the air out of the dispenser and allow you to fully fill compartment . the light should go off .
Mar 04, 2010 • Dishwashers
Dishwasher not working and rinse aid and eco light flashing.
you must fully fill rinse agent close the door raise the door up and down 3 times then add more liquid tolet out the air ,repeat until fully filled then turn on hot water until it get the hottest THEN START THE MAVHIN. problem should be solved.
Mar 02, 2010 • Dishwashers
4helpful
2answers
Cannot unscrew cap on rinse aid compartment in door of Whirlpool Gold Quiet Partner III
the cap doesn't come off, you just have to open the door all the way. then, when you pour the rinse aid into the dial area, it will get sucked into the dispenser. but if the door isn't open all the way it won't go anywhere and will overflow on you.
Jul 08, 2008 • Dishwashers
6helpful
Hotpoint DWT10 Dishwasher error codes/lights
food stuck in drain pump remove and clean out or scoop out - soak up all water then fill with 3 or 4 hot litres of water . cancel programme , start new one ( first thing unit does is switch to drain cycle ).
Then rock machine back and forth - this sometimes frees jammed debris thus pumping out of machine.
This works for me i have done it several times and it works
Jan 26, 2008 • Dishwashers
Top KitchenAid Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
