Question about Hotpoint Dishwashers
Hotpoint fdl570 dishwasher the salt,rinse aid and flashing 6hr drying lights are flashing on my dishwasher after about 5 minutes into a wash cycle.i have pulled out the machine tipped it to check for
Hotpoint fdl570 dishwasher the salt,rinse aid and flashing 6hr drying lights are flashing on my dishwasher after about 5 minutes into a wash cycle.i have pulled out the machine tipped it to check for water in the bottom.the pump pumps out the water .the hoses aren't kinked.but the machine does the same every time.but the first time it happend it tripped the power at the main board. Is the control board (on the machine) ?requires replacing ?or could the water heater be the problem? A desperate man!!!!
Posted by Nigel Chapman on
Thomas Beaver
  • Hotpoint Master
  • 2,119 Answers
Did water get into the control panel?
Some youtube videos that may help.
Hotpoint fdl570 YouTube
Posted on Oct 11, 2014
Testimonial: "To be honest I don't know, but would it still try to go through a cycle or would the pcd board just make the lights flash?or could the heater be the problem as after the first 5 minutes the heater starts to heat the water and this causes the flashing light thanks Nigel."
2 Related Answers
Anonymous
SOURCE: Flashing lights on Hotpoint FDL570 Dishwasher
I had an identical problem with the salt and rinse aid lights on the left and the drying and end lights on the right flashing shortly after switching the dishwasher on. When I pulled it out, as this was the only way to look at the pipework, I noticed a big kink in the water hose. Removing this and obviously sorting out the flow problem has resolved the issue.
Posted on Apr 08, 2010
tatianarudac
Tatiana Georgiou
SOURCE: Ariston Dishwasher LD87, error code AL03
for code al03 ,today i resolve the problem it was a pomp like everywhere in sites riding. we open a popm and there have a black lastic and it was inside of the pipe ,so we take it litl bit out and dishwasher work perfect !! it is easy ! dont be afraid to fix it alone .Just be carefull with a lot of water will come out from the pipes. and sore has to be away from electicity)good luck !
Posted on Aug 24, 2012
AEG 50879
This option can be selected by pressing the corresponding button, and remains in memory until the same
button is pressed again. This option modifies the phases of the programme in order to optimize performance
when "3 in 1, 5 in 1, 7 in 1, ......." detergent tablets are used:
- variation of the duration of the programme and the temperatures required to dissolve the detergent tablets.
- reduction of water exchange
- exclusion of introduction of rinse-aid
- exclusion of regeneration
If you use a dishwasher in the traditional manner (detergent, rinse aid, salt) then the Multitab function is disabled. If you use tabs that are already on the market with rinse aid and salt there is a possibility during washing cycle to add a double dose of rinse aid. From rinse aid dispenser and rinse aid from tabs. This will lead to poor cleaning results, glasses will look like they have been washed in milk..To avoid that you must turn on "Multitab" function and thus exclusion of introduction of rinse-aid from rinse aid dispenser. This function also stops the regeneration and will not spend salt because salt is already in a tabs. Also extends the washing time because tablets need more time to dissolve in relation to the traditional powder detergent.
Dado
Jul 15, 2014 | AEG Dishwashers
My dishwasher will start any cycle then half way
The touch pad has gone bad. Common problem with the GE made dishwashers.
May 12, 2010 | Dishwashers
Mar 20, 2010 | Dishwashers
Dishes are not always dry, even after sitting overnight
hi
make sure you are using rinse aid as this helps to evaporate the water at the end of the cycle in the drying stage. I know tablets have rinse aid built into the tablet but this can wash away on some wash cycles and do nothing so even if you are using tablets i reccommend still using rinse aid.
Jan 24, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishes aren't clean. i have run vingegar and CR through the cycle but dishes and glasses still have a film.
The most common cause of film left behind is a broken heating element.
The heating element is not only used during the dry cycle, but also to raise the water temp. during the main wash cycle to activate the dishwasher detergent. Fixing the heating element should "clear" this problem right up!
Aug 04, 2009 | Zanussi 24 in. DA6141 Built-in Dishwasher
MY G892SCUPLUS MIELO DISHWASHER LIGHTS AND CYCLES ARE STUCK.
The rinse aid light means you are out of rinse aid. The salt light means you have to add salt to your built in water softener. If the drain/intake light is on, that is when you have a problem. It will flash when there is a problem. You have to count the flashes and that will tell you what the error is.
Sgt 48
Jun 01, 2008 | Miele 24 in. G892SCU Plus Built-in...
Lost manual, wheres rince aid comp
forget the built in rinse aid, it only works for a couple minutes during the whole wash cycle. go out and buy the rinse/aid or jet/dry package that hangs on the racks and works during the whole cycle. of course use only cascade powder soap and sparingly.
May 27, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint dishwasher dwf50
i had the same problem and like an idiot paid for hotpoint to come out and all the guy done was tip the dishwasher backwards to empty the water(which he didn't clean) and tell me that im using to much rinse aid and salt coz we use 4 in1 tabs hope this helps smiley
Mar 20, 2008 | Hotpoint 24 in. FDW60 Free-standing...
HELP WITH NON FUNCTIONING DISHWASHER
similar problems here, repair man says its fine but the salt light was on so i added salt and works ok now. Some dishwashers don't function properly without the salt and rinse aid, even though you're pills may have then included, you still have to add them seperately, dumb but necessary at times.
Feb 27, 2008 | Dishwashers
Whirlpool ADP 5966 Dishwasher using the complete salt load in 6 washes and coating all the dishes in salt that would not rinse off. I filled the salt and 6 washes later it was requiring a new load of...
Hello, we are sorry to hear that you are experiencing this problem with the Dishwasher. We would recommend having a certified technician out to diagnose the problem. If you would like further assistance you can send your name, phone number, address, model/serial numbers and the date on which you purchased the Dishwasher to [email protected] Thank you.
Apr 17, 2017 | Whirlpool 24 in. ADP5966 Free-standing...
Dishwashers Logo
559 people viewed this question
Top Hotpoint Dishwashers Experts
Marvin
Marvin
Mike
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
