There is a seep hole on the bottom of the case that keeps driping water i looked to see if it may be a gasket but it just looks like theres a gasket for the cover. i dont know it may have something to do with the empeller?
Hello
there are two different seals on the water pump. the oil seal and the mechanical seal. the oil seal helps seal out the oil from the trans case. the mechanical seal helps seal the coolant from going into the trans case, and vise versa.
the weep hole is there to help diagnose if either seal is faulting. so if coolant is leaking from the weep hole. the mechanical seal is faulting or if the oil seal is leaking oil will drip from the weep hole.
hope this is of some help. thank you.
I have the same i have coolent leaking from the weep hole . Is it hard to change over.
