SOURCE: Bissell Model 3593-2 Upright purchased 3 years ago not drawing up dirt as it use to
Check where there is suction...is there good suction at the hose...at the back of the vacuum. Knowing where there is good suction will help you know where there might be a clog or any resistance. Bissell also has a fairly good customer support line...I believe the phone number might be on the vaccuum possibly in the back.
SOURCE: kirby heritage mark 2
There should be another wire to which it attaches nearby. If you cannot find it, do not try to 'invent' a repair...get help.
SOURCE: Roomba Discovery
I read somewhere that you need to clear the software in case there is a glitch. To do this, take the battery out and then, simultaneously hold down the "spot" and "clean" buttons for 30 seconds. Replace battery. This has worked for my Discovery model.
SOURCE: I have a bosch generator
I would empty the water out and attempt to flush it out and steam some C.L.R through it
take the head off then take to the nearest garage and use there vac to **** it out or the blow it out with there compressor.
