SOURCE: my dell inspiron mini 10
Remove the battery, and unplug the A/C adapter and hold down the power button, for 40 seconds.Soon your laptop will reset,and run well.Now you will install all the accessories and start.
Hope this helps you.
SOURCE: hi i have a vostro
First 2 of your problems are due to the fact that your laptop enters hibernation (or hybrid sleep in windows 7) and windows cannot restore your last saved state. The 3rd problem indicates you have windows problems (bad/not updated drivers, filesystem corruption, application issues). I would suggest you to reinstall windows.
SOURCE: My Dell inspiron mini Sometimes won't turn on, and
It might be your battery. Same thing happened with me, and when i got it replaced it was all good. so check the battery.
Remove the main battery and try again, also! the power adapter charger should be checked for correct voltage, if okay! pull one stick of ram and test, and the second piece not forgetting to put the first one back and power up, if all this fails you will need to get it assessed.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
