Need a wiring diagram for stereo in my 1991 volvo 960 wagon.
On this website, you wiring diagram - audio for Volvo 960 (1992) - maybe it helps you
Volvo 960 1992 1994 wiring diagrams audio
SOURCE: 1992 960 volvo wagon 208k.
If you can remove the stereo then you can most surely open the case of the stereo to find out if there's a fuse inside it. I'm a pretty good mechanic and it took me many hours to get the steroe out of my 940, 1991 model. There is a blade type fuse on the back of most Volvo units. If this is OK then re check your main fuse board. I have recently found that my 91 turbo model has a separate fuse for the rear speaker amplifier whilst trying to find out why the rear speakers had suddenly stopped working. It pays to consider the obvious things first though this usually only evident in hindsight. Persevere!
SOURCE: Radio will not power on
I had an identical problem, but i fixed it with a dew fuses, it turns out that these volvos have 3 different fuses for the radio, there are two inside the car in the panel, and the third is under the hood just behind the battery. See if any of those fuses are bad, if all the fuses are good, check the connections behind the radio, i had to pry the connections to make them fit better on the back; if none of this works, then its most likely a bad radio or faulty wiring...
SOURCE: Volvo headlight problem
headlight relay is the problem. it is located in dash above radio in a fuse cluster. local autozone can tell you exactly
SOURCE: Hi, I am installing a
Red is for constant power, yellow is for ignition power, blue is for an electric antenna, black is ground. The others are for the speakers. - 2blue, 2green, 2purples, 2whites. If you don't have an electric antenna , don't use the wire. Also if you extra wires for the vehicle this is common. don't use them. Hope this helps. Randy
Click
the link below: ---
Cigarette
lighter, Remote central locking, and Radio stopped working
http://whoisbyme.blogspot.in/2012/07/cigarette-lighter-remote-central.html
VW passat radio off safe
mode? VW radio CODE?
http://schematicsdiagram.blogspot.in/2012/03/vw-passat-radio-off-safe-mode-vw-radio.html
How to wire new Radio on
1990 Toyota Celica?
http://schematicsdiagram.blogspot.com/2011/12/how-to-wire-new-radio-on-1990-toyota.html
Radio Stereo Wiring Diagram
for 1991 Chevy 1500?
http://schematicsdiagram.blogspot.com/2011/12/radio-stereo-wiring-diagram-for-1991.html
How to remove radio on
Acura Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-radio-on-acura-car-models.html
Where is Radio Fuse located
on 2007 Dodge charger?
http://schematicsdiagram.blogspot.com/2011/12/where-is-radio-fuse-located-on-2007.html
How to reset Radio code
after car battery is died?
http://howtobyme.blogspot.com/2011/12/how-to-reset-radio-code-after-car.html
Can car radio code block
Passkey anti theft system ?
http://schematicsdiagram.blogspot.com/2011/12/can-car-radio-code-block-passkey-anti.html
After Market Stereo wiring
for 1999 Chevrolet Silverado 1500?
http://schematicsdiagram.blogspot.com/2011/12/after-market-stereo-wiring-for-1999.html
Chevy car radio doesn't
allow to switch to the XM Band to get the radio ID?
http://schematicsdiagram.blogspot.com/2012/01/chevy-car-radio-doesnt-allow-to-switch.html
No power to radio on 2005 Toyota Scion Xb?
http://repairhelpcenter.blogspot.com/2012/01/no-power-to-radio-on-2005-toyota-scion.html
Lexus rx330 Radio has power but no sound?
http://repairhelpcenter.blogspot.com/2012/01/lexus-rx330-radio-has-power-but-no.html
Radio goes ON and OFF while driving?
http://technoanswers.blogspot.com/2012/01/radio-goes-on-and-off-while-driving.html
Lincoln Town Car Radio stereo
wiring?
http://technoanswers.blogspot.in/2012/02/lincoln-town-car-radio-stereo-wiring.html
Radio wiring diagram for 1997 Lincoln Town Car?
http://technoanswers.blogspot.in/2012/02/radio-wiring-diagram-for-1997-lincoln.html
How to remove cd player from dash on 2003
Lincoln Aviator
http://technoanswers.blogspot.in/2012/01/how-to-remove-cd-player-from-dash-on.html
These details will help you thanks.
For Radio related problem,the help links are below.Click the link below to go through its procedure:-----Car radio works but CD player not working?http://technoanswers.blogspot.in/2012/02/car-radio-works-but-cd-player-not.html-----------How to reset Radio code after car battery is died?
------------- Can car radio code block Passkey anti theft system ?
How to wire new car Radio?
Radio Stereo Wiring Diagram?
How to remove radio on Car models?
Where is Radio Fuse located?
----------- After Market Stereo wiring?
car radio doesn't allow to switch to the XM Band to get the radio ID?
No power to radio Scion Xb?
Town Car Radio stereo wiring?
Radio wiring diagram for Car?
How to remove cd player from dash?
This will help.
Thanks.
