SOURCE: speaker impedance and the Yamaha RXV 463
You risk to crash a set of speakers. In any case this will have a detrimental effect on the sound
SOURCE: 4 ohm speakers with 8 ohm receivers
Please check with the manual of your receiver whether it is capable of running 4 ohm speakers.
if yes, then please go ahead, you will not loose any Sound quality. Sound quality will depend a lot on the performace of the speaker as well as the frequency range it can deliver.
If no, please do not connect. Though, you might be able to play and listen to the music, but it will overload your receiver!!
If you are not sure, please let me know the brand and model of your receiver and I can check for you.
Please do rate this solution and thanks for using FixYa!
SOURCE: With my RX-V663 can I use presence speakers less than 8 ohms?
Basically you can use any speaker as long as you use the volume button wisely. Damage will only occur if you raise the volume level to the extremes. Bigger speakers should be no problem, if you want bi-amping, your speakers should support that as well.
SOURCE: can I mix 6 and 8 ohm speakers?
Most Yamaha HTR's are high current receivers so setting the receiver to 8 ohms and running the 6 ohm speakers shouldn't be a huge problem. I wouldn't crank the volume though if i were you but at a decent level you should be fine.
