Motorola Mobility RAZR V3 Logo
Posted on Mar 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sim blocked Messed around with those oh so convenient security settings to keep people outta my phone annndd... ended up locking myself out! need a pin1 unblock code?
Anonymous
Level 3:
  • Master 464 Answers
  • Posted on Mar 18, 2009
Anonymous
Master
Level 3:
Answers
464
Questions
Helped
133687
Points
1495
You have to call your phone company before you can do anything. They are the only ones who can unlock your phone.
1helpful
My phone keeps asking for a restriction code. I got a weird call and then messed around with my security features, unaware of what I got myself into. Now it's locked after 20 minutes of being on...
Your cell phone may be locked to a particular cell phoneprovider and in this case it needs to be unlocked to use with a different cellphone service provider. To get the security code/restriction code to unlock thecell phone from the current cell phone provider so you can use the SIM cardwith a different phone provider, Please click on this link and follow myinstructions :- http://www.fixya.com/support/r4049238-unlock_cell_phone If your phone provider does not help you then this WEB siteit provides security codes for a small
price. http://www.mobileunlockstore.com/?gclid=CKDb2_y2558CFSlJagodxBkDHw Try this WEB sites - http://www.superunlockcodes.com/unlock-your-phone/rs12wp2/ http://www.unlock-free.com http://www.unlock-zone.com/ http://www.unlocking.com/
Phone says invalid usim, i have codes that get me out of this an to the next screen however its asking for an nck code the phone is an lg viewty ku990 on vodafone, i want to stay with vodafone and the same...
Try default codes or master rest codes to reset your security settings ,invalid sim is due to the network lock you na\may contact the service provider if you need to unlock it using codes try here http://www.mobileunlocksolutions.com/
Daughter messed around with settings put in pin lock and then phone asked for pin which my daughter forgot and now phone is asking for puk code pls help
The pin code is for the SIM-card
Contact your service provider for PUK-code.
This is your solution! Please remember to vote!
May 10, 2010 • Cell Phones
1helpful
Cell blocked
Securing your Shine
Secure your LG Shine and your account from thieves by locking your phone and your SIM card Losing a phone through accident or to a light-fingered thief is annoying, frustrating and potentially very costly, especially if the 'finder' uses your SIM card to make expensive calls. You can, however, lock both your phone and your SIM card with four-figure PIN numbers to prevent unauthorised use.
The first line of defence is to set a SIM card PIN. This means that whenever you turn on your handset you have to enter a PIN code before the SIM can be used. The default PIN code for your SIM is dependent upon your network; usually it will be found in a small booklet that came with the SIM card.
The PIN can be enabled, disabled or changed from the Security menu – but you only get three chances to enter it correctly. After those three, the SIM will get locked and can only be unlocked by entering the PUK (PIN Unlocking Key) which your network can give you. Enter the PUK incorrectly 10 times, and the SIM will be irrecoverably locked.
To activate a PIN code request, open the main menu by clicking on the scroll wheel. Click 9 to access the Settings menu and click 6 to enter the Security menu. The first item is PIN code request - click 1 or OK to open it. By default this will be set to off. To activate a PIN request, click 1; you'll now be prompted to enter the four-digit PIN. When you've done this, click OK, and if the pin was correct, you'll see the confirmation message 'Complete'.
To deactivate the PIN code request, you would simply select Off from the menu by pressing 2; you'll need to enter the PIN code whenever you change this setting.
PIN code request prevents another user from using your lost or stolen SIM card in their own phone. To lock your phone, and thus render it useless to a thief, you can activate Phone lock.
Two levels of handset locking are available. The first - called 'When power on' in the Phone lock menu - is to require an unlock code to be entered whenever the handset is switched on. This can be confusing and irritating when used together with the SIM PIN, so a second option is to only request the handset unlock code when the SIM card has been changed - called 'When SIM changed'. This means that if your phone is stolen, the thief can't use their own SIM card in it as the phone will need a PIN code to unlock.
To activate either option, go to the Security menu (clicking 9 for Settings and 6 for Security from the main menu) and click 2 to enter the Phone lock menu. Click 2 to activate When power on or 3 to activate When SIM changed. In either case you'll be prompted to enter the security code. By default this is 0000. Enter the code and click OK to confirm.
To change either code, go to the Security menu again (clicking 9 for Settings and 6 for Security from the main menu) and click 5 to enter the Change codes menu. To change the handset's security code, click 1 to select Security code, or to change the SIM PIN, click 2 to select PIN1 code. In either case you'll be prompted to enter the old code before entering the new code twice, clicking OK to confirm each time.
8helpful
5answers
Nokia 5310 security code unlock
If your phone is blocked. You will have to take it to your nearest network provider outlet to get it unblocked.
If your sim card is blocked. You can go to your network suppliers website, where you can obtain the puck code to unblock the sim.
Playing with setting
It shows that your Security Settings have blocked your Phone. To resolve this, you should take your Mobile Phone to the Service Center with Original Purchase Bill.
Jul 06, 2008 • Cell Phones
2answers
Phones pin is blocked (PUK)
You need to get the code from your mobile operator.
Pin blocked
Complete information :
The SIM card protects your subscription and not the phone from unauthorised users. If you change SIM cards you can still use your phone with a new SIM card. Most SIM cards are blocked at the time of purchase. If your SIM card lock is on you have to enter your PIN (Personal Identity Card) every time you turn on the phone.
If you enter the wrong password three times in a row the SIM card gets blocked. This is indicated by the message PIN Blocked To unblock this you need to enter your PUK
Note:
card (Personal Unblocking Key). Your PIN and PUK is supplied by your service provider. You can edit your PIN and select a new four to eight digit number
  • If the Message Codes do not match appears when you edit your PIN you entered the new PIN incorrectly.
  • If the message Wrong PIN followed by Old PIN appears then it means that you have entered the old PIN incorrectly.
To unblock your SIM card:
  1. When PIN Blocked appears enter your PUK > OK
  2. Enter a new four to eight PIN > OK
  3. Re-enter the new PIN to confirm > OK
To edit your PIN:
  1. > Settings > the General tab > Security > Locks > SIM Protection > Change PIN
  2. Enter your PIN > OK
  3. Enter a new four to eight digit PIN to confirm > OK
To turn the SIM card On /Off
  1. > Settings > the General tab > Security > Locks > SIM Protection > Protection and select On or Off
2answers
Locked up phone
pin coad blocked 2310
6helpful
3answers
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
