Problem with Element Electronics FLX2211B 22 in. LCD TV. Program blocked message pops up on screen for 3 to 5 seconds while watching TV. How can I stop this from happening?
Program blocked appears on my element tv all the time...it drives bananas,what can I do?Program blocked appears on my element tv all the time...it drives bananas,what can I do?
my element flat tv has no volume and pictures are in black and white why? help me please.my element flat tv has no volume and pictures are in black and white why? help me please.
You can't post conmments that contain an email address.
Ur tv have a dead board that call the LCD inverter board.This LCD inverter board it is a Long board.It only job are to provided a backlight to the tv LCD screen panel to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a long refurbish LCD inverter board for the replacement.
I have run into the same problem with a different model (32 inch from Circuit City). You may have found that there is almost no support from the co or web. I do not have an official solution but have some work arounds that have done the job for me. WA#1 = after a channel scan tune to a HD/digital channel before you turn the set off. You need to do this each time for several times, because the set when turned on to a regular cable or analog station will default to skip all channels. After several times the set should remember your channels. WA#2 = after a channel scan, go to the skip channel section of the menu, and if your remote has the colored buttons on the bottom scroll through the channels using the red and green (up and down on this menu) buttons. This apparently helps the set remember not to skip your scanned channels. These are not glamorous solutions but appear to trick the TV into not re-setting the skip function for the channels. Best of luck.
no pass word dont know
2211b
element
cant get rid ofblocked program c-//////?????????
