Question about Element Electronics FLX2211B 22 in. LCD TV
Element Electronics FLX2211B 22 in. LCD TV will reset every time
My Element Electronics FLX2211B 22 in. LCD TV will reset every time it is turned on. I need to change the tuner mode from "AIR" to "CABLE" then run a channel scan every time I turn it on. It certainly is not right.
Any suggestions?
Posted by michelleandk on
  • Anonymous Mar 25, 2014
    hello
Anonymous
I have run into the same problem with a different model (32 inch from Circuit City). You may have found that there is almost no support from the co or web. I do not have an official solution but have some work arounds that have done the job for me.
WA#1 = after a channel scan tune to a HD/digital channel before you turn the set off. You need to do this each time for several times, because the set when turned on to a regular cable or analog station will default to skip all channels. After several times the set should remember your channels.
WA#2 = after a channel scan, go to the skip channel section of the menu, and if your remote has the colored buttons on the bottom scroll through the channels using the red and green (up and down on this menu) buttons. This apparently helps the set remember not to skip your scanned channels.
These are not glamorous solutions but appear to trick the TV into not re-setting the skip function for the channels.
Best of luck.
Posted on Jun 03, 2009
Sansui tv do not turn on
First place to look if total dead is inside for a fuse and then examine the power board inside for any puffed up filter caps.
Dec 14, 2012 | Element Electronics FLX2211B 22 in. LCD TV
TV is on one channel and will not work with remote or allow me to change channells from side of tv
I've run into this same issue. Although not a complete fix, I was able to program the tv with a basic universal remote. Try using the Goldstar remote codes. While I'm unable to use the channel buttons, I can change channels manually and turn the tv on/off and use the volume button. Again, not a fix, but a work around for now.
Jun 25, 2011 | Element Electronics FLX2211B 22 in. LCD TV
Element 22" will not come on either by the remote or the side pan
Please check the power supply board for bloated capacitors/fuse. If there are any signs on life i.e. turns on, shuts down, green lights come on etc.
Feb 17, 2010 | Element Electronics FLX2211B 22 in. LCD TV
Hi, i have a flx-2211b element electronics tv and I have a xbox 360 hooked up to it through a HDMI cable but the tv says unsupported mode. what do i do to fix it?
I have the same problem with my 360 i am just going to by a new tv i cant find the remote code. or any thing and the hdmi port don't work that's my answer this TV sucks and it is ****..
Jan 07, 2010 | Element Electronics FLX2211B 22 in. LCD TV
My flx-2611b elements tv stopped working today. the power light does not come on now. Is there any way to reset this tv?
this a defective board, psu or inverter board, need to be checked. send to electronics repair store.
Dec 20, 2009 | Element Electronics FLX2211B 22 in. LCD TV
Element Electronics FLX2211B 22 in. LCD TV Logo
1,833 people viewed this question
Top Element Electronics Televison & Video Experts
Mike
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
