SOURCE: jvc hxd7 system problem
mine does the same took it apart and there is a hole burnt through the audio output board (AH41-00836A) cant find the board if I do think it would be better to buy new system
SOURCE: how to unlock protected mode on a jvc 5 disc cd changer?
cheack the speaker wireing.if thats not the pro i sugg the repair shop your unit could have over heated.
SOURCE: my jvc hxd7 system won't
Possible fault in the audio output power IC.
Release the main rail voltage to the unit to confirm the fault .
Replace the IC, before conneccting the speakers, check for any shorting.
Remove connectors carefully so as not to damage.
Use a good desoldering tool.
First you shutdown your computer, then disconnect all power cords. I don't know if you have a tower or a deskpro, with the tower just slide the panel out pulling from the back, you may have to remove a piece from the front with a tower. Pay attension to how your cd rom is hooked up, I don't know if this is a combo (cd/dvd/RW) if it's a combo, if it is a combo you would have to take out the old drive and replace with the new, just pay attenion to how the old drive is hooked there should be two cords to connect to . If there separate drives there should be an empty bay. Let me know how your doing, and if I can assist you more.........Thanks, Heidi
