Ok? Do you have a problem with temp gage? Does it work? Are there any applicable trouble codes for the instrument cluster? Some of the national brand auto stores in the US will check codes for free.
With some vehicles, you may be able to get instrument cluster to self-test. Press and hold odometer reset button, turn ignition switch to run, release odometer reset button. Any stored 3-digit code will be displayed in the odometer vf display. The vf display will perform sequential segment test. All indicators, "data controlled" will illuminate. All gages will cycle in 12 or 15 % increments. The cluster internally commands all non-hardwired indicators and gages to operate.
I can only talk in general terms, I don't know if this will work on your particular vehicle?
An inverter, in a laptop, is not something which can be reset, it's either good, or bad. If it goes bad, it needs to be replaced, it's not a very complicated job for a professional to do. The part is generally about 15 to 20 dollars, and the labour should not be any longer than 30 minutes. the whole job should NOT cost more than 35 to 45 dollars to have done. Any more and you should question the professional, or get someone else to do it!
Follows are the part of the manual
Possible causes
• The cooling fan does not rotate.
• The ambient temperature is too high.
• The vent is blocked up.
• A heat generating device is installed close to the inverter.
• The thermistor in the unit is broken. Remedies
Restart the operation by resetting the
inverter after it has cooled down enough.
• The fan requires replacement if it does
not rotate during operation.
• Secure sufficient space around the
inverter.
• Do not place any heat generating device
near the inverter..
If you're battery's dead -- won't hold a charge ... replace it with a new one. Otherwise,y
ou'll have more problems than just a code. The code should reset once the battery is performing properly. When storing a bike for a cold winter, remove the battery and keep it on a trickle charger indoors.
Contact your service provider or Nokia and ask them for a
code to unlock your phone. They should give you this code for free. Make
sure you write the code down so you will remember it in the future.
Find software online to download that will unlock your
phone. Most Web sites offer this type of software for free. Try
searching for this type of software on search engine sites like Google
or Yahoo.
Locate the serial number (or the IMEI number) of your phone. Check underneath the phone's battery for this.
Download the software and begin entering in the manufacturer
(Nokia), the serial number, and the phone's model number. A list of
codes will be displayed. Write down these codes.
5
Remove your SIM card and turn on your phone. Then, enter the
code into your phone, including the number signs. Do this after the
"Insert SIM Card" display appears.
