When i turn on my camera it makes the normal noise but then it makes a wahhh wahhhhh noise and the light on the wheel goes from green to orange and the memory card is empty
When a camera makes a noise that isn't normal, usually it's a mechanical failure of the lens. Remove the battery for a few minutes and turn the camera on and attempt to take a picture again. If it doesn't work, I can venture to guess that the camera's lens mechanism is defective.
The Vibration reduction system does move components inside the lens. If it makes a lot of noise you are better off turning it off and using a tripod. The VR system will move lens components to counteract your motion. The steadier you hold it (camera and lens) the less noise. On small Coolpix cameras the sensor is moved to counteract the vibration while it is hand held.
Windows updates change the registry. Sometimes this means our connected equipment no longer works. Now it is time for you to start using a separate card reader.
hi! What you describe sounds perfectly normal! While powering on the camera, it takes out the lens and perhaps doing some mechanical self-tests. All this means moving parts using little servos inside the camera. Same happens when taking pictures - the lens moved, the shutter closes (and reopen), etc... While watching the pictures you've taken, you're only reading digital info. from the memory cards - no moving parts, no mechanical movements - hence, no noise!
if u have dropped ur camera, then it is a mechanical fault. take it to the nearest service center. u can remove your memoy card and put it in an media card reader and view ur pictures,
