Tip & How-To about Cameras
Kodak EasyShare Z740 Turns Off Fix
Does your Kodak EasyShare Z740 Turns On Then Turns Off right away?
Does your Kodak EasyShare Z740 Turns Itself Off with new AA batteries in it?
Many of these Kodak EasyShare Z740 cameras that shuts off right away and will not stay on, will actually stay on if you select FAVORITES to view pictures, but just flash back and turn off if set to auto or camera mode. Try this.
If the lens cannot extend, the camera will turn itself off. You can try giving the camera a thump with the heel of your hand, but I would recommend servicing the camera rather than smashing a delicate digital instrument. After trying the steps below, a last chance alternative that works for some people is to grab and actually PULL the lens out as it tries to extend itself. Again, its delicate; if you can afford it, maybe pay for servicing before hitting and pulling on your camera.
However, before servicing your Kodak Z740 try this fix:
  1. Hold down the Time/Ascending Folder button (the button under OK on the circular panel)
  2. While holding that down, press and hold the ON/OFF button.
  3. The camera may turn itself on and stay on this time, acting normally again.
If this doesn't work for your try this:
  1. Hold down the '>' button (the one that brings you to picture review)
If that doesn' t work, try again with the 'Trashcan' button, and ON/OFF button.
I hope that helps.
____________________________________
Kodak EasyShare Z740 Manual Download
Cameras Logo
my camera turns on but turn off right away why?
I may be able to help with your Kodak EasyShare Z740 that turns itself off.
It may be a 'lens extending' problem, or it might be fixed with a combination of button presses to reset it while turning it on.
Try these steps to fix your camera.
I hope that helps.
_____________________________________________
Apr 27, 2010 | Kodak EasyShare Z740 Digital Camera
Kodak EasyShare Z740 Turns Off Fix Does your Kodak EasyShare Z740 Turns On Then Turns Off right away? Does your Kodak EasyShare Z740 Turns Itself Off with new AA batteries in it? Many of these Kodak EasyShare Z740 cameras that shuts off right away and will not stay on, will actually stay on if you select FAVORITES to view pictures, but just flash back and turn off if set to auto or camera mode. Try this. If the lens cannot extend, the camera will turn itself off. You can try giving the camera a thump with the heel of your hand, but I would recommend servicing the camera rather than smashing a delicate digital instrument. After trying the steps below, a last chance alternative that works for some people is to grab and actually PULL the lens out as it tries to extend itself. Again, its delicate; if you can afford it, maybe pay for servicing before hitting and pulling on your camera. However, before servicing your Kodak Z740 try this fix: Hold down the Time/Ascending Folder button (the button under OK on the circular panel) While holding that down, press and hold the ON/OFF button. The camera may turn itself on and stay on this time, acting normally again. If this doesn't work for your try this: Hold down the '>' button (the one that brings you to picture review) While holding that down, press and hold the ON/OFF button. The camera may turn itself on and stay on this time, acting normally again.If that doesn' t work, try again with the 'Trashcan' button, and ON/OFF button. I hope that helps. ____________________________________ Kodak EasyShare Z740 Manual Download
May 01, 2010 | Kodak EasyShare Z740 Digital Camera
Camera turns off when you use telephoto lens camera turns off.
I hope that helps.
Apr 21, 2010 | Kodak EasyShare Z740 Digital Camera
kodak easyshare Z740 battery problem
I hope that helps.
Oct 22, 2009 | Kodak EasyShare Z740 Digital Camera
I hope that helps.
Nov 05, 2008 | Kodak EasyShare Z740 Digital Camera
7,302 people viewed this tip
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
