The starter has been replace twice, the first time Jan 08 batt power not start
2nd time starter rngaged but did not dis engaged and burnt
replaced with third starter now its doing the same starts but starter stays engaged
any suggestions
could it be the ignition switch?
If that starter is damaged then replace it and make sure that you shim the starter correctly or it will bind the gears and do the same thing again.
i dont belive this starter has shims
its a direct fit
i put this starter in on Thursday the 12th of March
no teeth missing on the fly wheel
stater drive is fine
there is no missalignment marks
could it be that the key switch is sticking?
when it stick and you shut it off it stays engaged
put the key in the on position again it starts the van and disengages
some time you have to do this more than once
